30 Pages «<1819202122>»
Stevie's Vic Build Options
Martyn Ingram
#381 Posted : 28 January 2014 09:45:03
BigGrin Lovely work Stevie nice tip on the dead eyes ThumpUp Good luck with the rigging BigGrin Rgd Martyn
Building Soleil Royal by Deag
Completed. Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel Wasa
Next Build Santisima Trinidad
#382 Posted : 29 January 2014 18:58:13
Thankyou Martyn, Just a small update again and a few more pics, the lower shrouds are now all done apart from the lanyard knots which come later after final tensioning and when the stays are in place.
I'm pleased with this bit, looking forward to doing the same on the topmasts nextBigGrin
#383 Posted : 29 January 2014 22:17:24
Groups: Tech Support, Registered, Administrators, Global Forum Support, Moderator
Think you should be pleased with that part of your build Stevie, it's like the rest of it... beautiful....Drool Drool
#384 Posted : 30 January 2014 15:17:07
Hi Steve.
Looking Superp. Look forward to seeing more. IanCool BigGrin
sparks
#385 Posted : 31 January 2014 20:24:55
Looking good Steve Drool
#386 Posted : 31 January 2014 20:49:39
I think the deadeyes look much better black, looks Cool
#387 Posted : 31 January 2014 22:45:11
#388 Posted : 31 January 2014 22:46:12
#389 Posted : 31 January 2014 22:49:27
Thankyou Mr T.BigGrin I noticed that the real deadeyes are black so thought Id go with that, thanks for looking in
Another day of knots today, futtock shrouds done - Tomorrow it's "Return of the Deadeye"BigGrin (had to get that in somewhereLOL) - topmast shrouds next!.
#390 Posted : 01 February 2014 00:10:04
BigGrin Hi Steve
Some nice tidy work thereDrool
regards
AndyCool
Global Forum Support Team
#391 Posted : 01 February 2014 00:12:41
Nice futtocks Stevie, stunning work.....Cool Cool Looking forward to Deadeye's return....BigGrin BigGrin
#392 Posted : 02 February 2014 14:04:41
#393 Posted : 02 February 2014 14:08:30
#394 Posted : 02 February 2014 14:14:23
Well this was to be "Return of the Deadeye" but as I have already posted the mini tutorial showing Deadeye Dave Jr. in use I just thought Id show some pics of the completed topmast shrouds instead rather than repeat the tutorial -
http://forum.model-space...aspx?g=posts&t=9532
Im on issue 96 now and have only skipped 2 jobs, fitting the bowsprit and the 4 lanterns. Im holding off fitting the bowsprit until I absolutely have to as it will make spinning the model around more difficult, plus I still havent built a shelf yetAngry With the bowsprit in place the Vic will have to come off the desk.
Thanks for looking BigGrin
#395 Posted : 02 February 2014 20:58:30
Lovely work as usual Stevie and I like your idea of using thinner thread for the ratlines.... will be interested in how it will look....Cool Cool
#396 Posted : 02 February 2014 22:22:45
Thanks Alan, when I get to the ratlines I may do a little test piece to see how each looks and post on here to get some opinions on it.
Cheers
Steve
#397 Posted : 02 February 2014 22:44:40
BigGrin Hi Steve
Your right the knots would be out of scale but its a half way house as the majority of the blocks supplied are also out of scale or too big , so its a case of if it looks right it will be ok .
You also have the problem that during a voyage only so many spares could be carried on board so at some point a larger block would be used until the correct replacement was available.
regards
AndyCool
#398 Posted : 03 February 2014 10:04:31
arpurchase wrote:
BigGrin Hi Steve
regards
AndyCool
You are right Andy, most of the blocks are overscale, especially the gun tackle blocks which are currently about the same width as the cannon barrels!
I'm thinking I will be using the DeAg suggested route of pushing the ratlines through each shroud with a needle and only using knots at each endBigGrin
Steve
daffy09
#399 Posted : 03 February 2014 15:38:19
Build-Diary Medal: Build-Diary Medal of HonourActive Service Medal: 500 post active service MedalRed Medal: Red MedalOutstanding Build: An award for an outstanding build
Lovely work Steve and very neat.
I love your "Deadeye Dave jnr" tool. A brilliant invention on your part. I'm just about to reach the stage where it will be needed so with your permission, I'd like to make one of these little gizmo's myself, and looking at your build and tutorial, it really makes life easier there.
Good luck and happy building
David
#400 Posted : 03 February 2014 15:53:51
David
Thanks for looking DavidBigGrin
Id love to see how you get on with "Deadeye Dave" Junior and Senior as you will need to make both, one at 20mm distance and one at 15mm. Just been looking through the Vic diaries...do you not have your Vic build log on here?
Cheers
Steve
This page was generated in 0.220 seconds.
