Stevie's M3 Stuart "Honey" Tank (North Africa Dio. Pt.3) Options
#1 Posted : 14 February 2014 18:11:28
Here we go with Pt 3 of my North Africa DioramaBigGrin
Pt.1 here
Pt.2 here
The M3 Stuart was first used by the British in June 1941 under a lend-lease agreement. Nicknamed "Honey" by the crews and used as a "shoot and scoot" due to it's top speed being 10-20mph faster than any Brit or enemy tank at the time.
The kit has a detailed interior and I have the full PE kit to go with it. Academy kits are usually very good and this one is no exception, beautifully molded, well detailed and absolutely no flash - this one is going to be enjoyableBigGrin
The usual sprue pics next, one point on the tracks - rubber tracks were supplied and look very good but you cant beat individual links which is what I will be going with. There are 392 pieces of track which equates to 66 links per side or 6 pieces for every 2 links of track - it's going to be funLaugh
#2 Posted : 14 February 2014 19:25:18
looking forward to this and the end duo
Kits on order = 5, Stash (not started) = 42. Stash (started) = 18, Live Builds = 4, Built since 1979 = 167
#3 Posted : 14 February 2014 22:51:03
BigGrin Hi Steve
Nice little tank
regards
AndyCool
Global Forum Support Team
#4 Posted : 17 February 2014 14:04:32
Thanks Jase & AndyBigGrin
Over the weekend I built the lower hull and wheels, I wanted to get these parts painted and base layer weathered before they went together. There are no visible lines where the upper and lower hull meet so no worries about the continuity of the finish when it goes together.
There was no point is taking pics during this part of the build, separate wheels and suspension assemblies were primed in black and then sprayed sand so some of the black shadowing could still be seen.
The fit so far has been a dream, absolutely perfect, better than any Tamiya kit I have made - its so good that no glue was required for the road wheels at all, not even to fit them to the hullBigGrin
I also got this part out of the way as there was no etch on the lower hull.
This tank wont be heavily weathered but there will be more layers on the wheels etc later, some chipping and sand pigment.
Moving on to the interior next so more pics soon.
Steve
Martyn Ingram
#5 Posted : 17 February 2014 17:54:34
BigGrin Stunning work as always Stevie keep posting the pics rgd MartynBigGrin
Building Soleil Royal by Deag
Completed. Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel Wasa
Next Build Santisima Trinidad X section
#6 Posted : 17 February 2014 20:26:51
#7 Posted : 20 February 2014 20:38:12
Got some work done on the interior last night, a black primer coat first, then a satin white enamel overspray, I made sure that the white spray didnt reach all the corners to make those areas slightly darker.
A black oil wash was next and lots of chippingBigGrin I have put in a couple of pics with the lid on showing that hardly any of this will be visible even with all hatches open which is why I didnt spend too much time on it.
It will be having a sandwash and the fire extinguisher is still not fitted. There is more interior work later inside the turretBigGrin
Steve
#8 Posted : 22 February 2014 14:43:26
Here's a few more pics with some dust / sand inside, that's the inside done now apart from the turret internals, I will probably brush a little of the sand pigment out before applying a lacquer as it looks a bit strong in the picsBigGrin
Steve
#9 Posted : 23 February 2014 08:55:12
Fabulous work Stevie, think you have the weathing effect spot on.....Cool Cool .. Will be following....
#10 Posted : 24 February 2014 00:32:52
Thankyou Alan, I have toned down the sand effect now and klear coated it again and that's it for the hull interior. The pic seems to look like all the sand effect is gone but it's not, same as the pics in the last post seemed too sandy but only on the photo, what is it with cameras?Cursing
Steve
Martyn Ingram
#11 Posted : 24 February 2014 09:44:35
BigGrin Looks Stunning to me Steve BigGrin Lovely workDrool Rgd Martyn
#12 Posted : 26 February 2014 21:44:28
#13 Posted : 26 February 2014 22:10:12
stevie_o wrote:
Thankyou MartynBigGrin More to come on this one tomorrow hopefully.
Steve
And I'll be looking in again when you post.... looking fab Stevie....Drool Drool
#14 Posted : 07 March 2014 23:15:24
Thanks Alan,
Moved onto the hull lid now, just building up all the parts and etch that are to be the same colour as the tank, everything else will be painted off the model. Used most of the etch supplied although there were a few bits that wernt necessary. A little filler here and there and then a grey primer. More on this one tomorrow.
Steve
Warthog
#15 Posted : 08 March 2014 10:18:34
Beautiful work as always Steve Cool
Spencer
#16 Posted : 08 March 2014 20:19:30
Thankyou SpencerBigGrin
A little more progress - I have put the base colour on the lid, it is based on the caunter cammo scheme and consists of a half and half of sand and mid blue / grey with some dark green on the turret as well.
Then for a bit of a change I built up the commanders gun with all the supplied etch as this is the gun on the turret top so is clearly visible. It's a lovely thing once complete though, really happy with it, so much detail when you consider it's only an inch longBigGrin
Steve
#17 Posted : 08 March 2014 20:33:01
BigGrin Hi Steve
As usual the etch makes all the difference, nice work
regards
AndyCool
#18 Posted : 08 March 2014 21:25:30
Looking great Steve, detail is really coming along..... Cool Cool
#19 Posted : 08 March 2014 22:01:04
Nicely done as always, and that bit of dry brushing has brought out the detail of the gun well Cool
J
#20 Posted : 09 March 2014 12:59:18
Thanks guys - working on the turret etch at the mo so more pics later although the wife has just asked me if Id like to go for a walk with her to the shops.....how inconsiderate LOL
Steve
