3 Pages <123
AndreZS1AZ BUILD DIARY Options
Chasecar
#41 Posted : 06 May 2016 20:22:27
That's cool
Chasecar
AndreZS1AZ
#42 Posted : 27 May 2016 09:27:35
What can I say, it's Friday and I am looking forward to the weekend. I received the replacement servo and radio this week. I will test them and then re-assemble the car. That should see me doing the break in of the motor this weekend if it does not rain. I am running on my own fuel which is 20% nitro and 18% castor oil. After the fuel is finished I will have to use commercial fuel until I can get some nitro as I have run out. Enjoy the build.
Cheers
It's not the fall that kills you, it's the sudden stop
Building: Bismark, scratch built electric hydroplane
AndreZS1AZ
#43 Posted : 22 August 2016 17:58:18
Received issues 96, 97, 98 and 98. Yes, you read correctly, 2 issue 98 and NO 95. I was promised that it will come within 2 weeks, but no problem. I have decided to do the engine break in as the car is and then strip it down to fit the 2 speed gearbox and try tighten up all the play on the suspension. I am going to take some photos and post them with comments. Your comments are welcome.
AndreZS1AZ
#44 Posted : 29 January 2017 16:28:35
Here's wishing you all for 2017. Received my last wheel last week and now I can try and finish the build.
AndreZS1AZ
#45 Posted : 21 June 2018 16:01:32
Hi Tomick, do hope that all is well that side. What a time I have had since last posting, been travelling and no time for hobbies, which was a bit of a pity. Right, let's discuss the RB7. There is so much slop/play on the the various suspension and steering parts. That is one of the reasons that I stopped building. I purchased a Hobby King buggy with better tolerances than the RB7. Well, it is back on the table and will be stripped down to Part 1 and I will rebuild and modify as I go along. The 2 speed clutch will also be fitted to give some more speed. Is there anyone willing to go along?
#46 Posted : 22 June 2018 06:07:50
BigGrin Welcome back and have fun with itCool
Global Forum Support Team
AndreZS1AZ
#47 Posted : 28 June 2018 16:32:56
OK folks, I am back with the RB7 build. It might be a bit late as I have been away doing other stuff. I think that everyone has already finished the build. I have all the issues up to 115 and will be building out of sequence as the mood takes me. I will have to strip my car down to sort out the sloppy issues and see how it goes. I did not finish the car because of the fore mentioned issues. I ran the motor and the car for a brief period and it runs well. Are there still people building the RB7? Pictures will follow.
AndreZS1AZ
#48 Posted : 30 June 2018 11:19:15
Greetings all, from a cold Swellendam, but it is winter here in South Africa. As I mentioned on a previous post, I am now building out of sequence because I do have all the parts.
I, myself, do not agree with the way we are told to glue the tyres onto the rims. Super glue is a different beast, batch to batch. This is how I did it.
Roughen the rims as per instruction. Fit the tyre and check that the bead is the same all around the wheel. Pull the tyre away from the rim and then put in the super glue as shown.
AndreZS1AZ attached the following image(s):
AndreZS1AZ
#49 Posted : 30 June 2018 11:22:50
AndreZS1AZ
#50 Posted : 30 June 2018 11:33:22
Hmm, actually a quick thought, not that I am capable of thinking after all the nitro flowing through me. Is anybody still building the RB7?
AndreZS1AZ
#51 Posted : 08 July 2018 17:08:58
All the tyres are have been glued and they seem to be true. We will take that with a pinch of salt until I run the car again. I am stripping the car down to the basics and will be rebuilding it. I have no problem with the display parts, it is the running parts that give me the stressCrying Did I see that the car now comes as a complete kit. or was I dreaming?
AndreZS1AZ
#52 Posted : 10 July 2018 16:20:17
Went to the local off-sales (bottle store/booze outlet) and got some cardboard beer trays. No, they were not full which is a pity. I will be putting all the parts into them when I pull the car apart. I must take a picture of the amount of play on the RH rear wheel before I strip it down. This seems to be the most. The glue that I used to glue the tyres is very thin and it wicks around the rim very nicely. I leave them overnight and check the next day that they are firmly glued on.
All comments are welcome.
3 Pages <123
