drawing the taper on the #6 planks Options
ronald305
#1 Posted : 10 July 2018 17:58:12
Hi Alan
I was able to mark the planks #6 around 1 or 2MM now I need your help
with tapering the planks since I do not own the particular ruler you used
in the video or as used in the instructions I do have the 15mm ruler but it does not show 130 but 13mm instead before I taper it I need to know do I mark the plank at 13mm
Ronald
#2 Posted : 10 July 2018 21:29:40
The ruler shown in the instructions is marked out in millimetres, the ruler you probably have will be marked out in centimetres. 130mm is 13cm so you need to mark the start of your taper at 13cm....
ronald305
#3 Posted : 10 July 2018 21:46:25
yes you are right mine is in cm but it shows mm on top and 0.5mm on the bottom but for the first time I was right for someone getting use to metric being from the states lol
Ronald
#4 Posted : 10 July 2018 22:11:26
Ronald
BigGrin BigGrin No problem. You could convert by dividing the centimetre measurment by 2.54 which would give you the size in inches, so 13cm divided by 2.54 would work out at 5.11 inches.
ronald305
#5 Posted : 11 July 2018 00:21:49
was thinking would it be easier to use an
X-acto knife to cut the taper rather then
sanding the taper just a thought
Ronald
#6 Posted : 11 July 2018 10:01:07
Ronald
I'd sand the taper, gives greater accuracy and a lot neater.....
ronald305
#7 Posted : 11 July 2018 16:25:44
ok thanks Alan
I did that for one of them drawing the taper wasn't easy had to find a way to keep the scarp and plank from moving on me and marking the 1.5mm wasn't easy either but I got it, P.S. may I ask where did you buy the 150mm ruler used in the video thank you
Ronald
#8 Posted : 11 July 2018 22:17:32
ronald305 wrote:
ok thanks Alan
Ronald
I got mine from here:
https://www.cornwallmode...og/measuring_tools.html
I would imagine you could find a US supplier for this item, perhaps doing an internet search produce results for you.....
ronald305
#9 Posted : 12 July 2018 14:59:58
is yours a 6" or 12" ruler yes the US might but cornwall models have better
products I could try to look for one here in the US
Ronald
#10 Posted : 12 July 2018 18:42:19
I use a variety of different rulers, not just the one....
This page was generated in 0.093 seconds.
