2 Pages <12
Graham's Easy Rider Build Options
#21 Posted : 07 June 2018 07:38:35
Nice start and a great choice of kit Cool
#22 Posted : 07 June 2018 08:54:40
Great start, looking forward to seeing your build progress....Cool Cool
pemberg
#23 Posted : 07 June 2018 11:12:58
Groups: Registered, Forum Support Team
Good to see your build under way, great start.
Graeme
mogwai
#24 Posted : 07 June 2018 18:46:55
Hi nice start,will be following with interest ,cheers mick.BigGrin
bugsec
#25 Posted : 21 August 2018 22:53:23
Thanks all - so here we go with Pack 02.
I'm going to slightly change the layout of my build diary as some build stages uses parts from two or more supplied stages. To cover that I'll detail all the parts supplied in a pack then describe each build stage for that pack.
Pack 02 contains Stages 04 - 09
Parts supplied:
Parts 04:
A - Handlebar
B - Handlebar clamp (lower)
C - Handlebar clamp (upper)
D - Screws x 3
E - Socket wrench
Parts 05:
A - Handlebar mount
D - Screws x 3
E - Spring
F - Front fork slider
Parts 06:
A - Front fork tube
B - Handlebar mount cover
C - Locator pin large
D - Spanner
Parts 07:
A - Lower triple tree
B - Front fork slider
C - Spring
D - Locator pin small
Parts 08:
A - Front fork tube
B - Upper triple tree
C - Domed screws x 2
D - Hex screws x 2
E - Locator pin small
F - Locator pin large
Parts 09:
A - Front wheel axle
B - Wheel shaft
C - Wheel nut
D - Spacers x 2
E - Nuts x 2
bugsec attached the following image(s):
bugsec
#26 Posted : 22 August 2018 06:25:28
Build Stage 04 - The handlebar.
Parts required:
B from Parts 04; A and B from Parts 05; B from Parts 06.
The two lower handlebar clamps are attached to the handlebar mount then the handlebar mount cover is attached to the handlebar mount.
bugsec
#27 Posted : 22 August 2018 06:26:12
Build Stage 05 - The handlebar contd.
Parts required:
A, C and D from Parts 04; C and D from Parts 05.
Also required:
Assembly from Build Stage 04.
The handlebar is attached to the handlebar mount and secured using the upper handle bar clamps and screws.
bugsec
#28 Posted : 22 August 2018 06:27:02
Build Stage 06 - The front forks.
Parts required:
E and F from Parts 5; A and C from Parts 06; B, C and D from Parts 07; A from Parts 08.
The spring is inserted into the left front fork tube followed by the front fork slider and secured using the locator pin.
This is repeated for the right front fork.
bugsec
#29 Posted : 22 August 2018 06:27:49
Build Stage 07 - The triple trees.
Parts required:
A and D from Parts 07; B, D and E from Parts 08.
Also required:
Assembled front forks from Build Stage 06.
The left front fork is attached to the lower triple tree and secured using the locator pin. The right fronk fork is also attached to the lower triple tree and secured with a locator pin.
The upper triple tree is attached to the front forks and secured using the hex screws.
bugsec
#30 Posted : 22 August 2018 06:28:37
Build Stage 08 - Connecting the handlebar and forks.
Parts required:
C from Parts 08.
Also required:
Handlebar assembly from Build Stage 05 and front fork assembly from Build Stage 07.
The handlebar assembly is attached to the front fork assembly and secured using the domed screws.
bugsec
#31 Posted : 22 August 2018 06:29:23
Build Stage 09 - Fitting the front wheel
Parts required:
A, B, C, D and E from Parts 08
Also required:
The handlebar mirror parts from Stage 02 and the front wheel from Stage 03.
The wheel shaft and nut are attached to the front wheel.
The handlebar mirror is attached to the handlebar using the clamp, washer and nut.
The front wheel is attached using the wheel axle, spacers and nuts with the nuts on the left fork. Both nuts are used to secure the axle.
#32 Posted : 22 August 2018 07:32:25
BigGrin Looking good
Global Forum Support Team
#33 Posted : 22 August 2018 07:58:54
Nice work, looking good.Cool
#34 Posted : 22 August 2018 08:23:46
Very nice, coming along beautifully....Cool Cool
#35 Posted : 22 August 2018 12:26:37
Groups: Administrators, Global Forum Support, Official Builds, Tech Support, Registered
Great work so far Graham BigGrin its going to be huge looking at that front end.
https://www.youtube.com/watch?v=qIC4f1LE86w
Built-Eaglemoss Orbiter,Solar System,Nissan GTR,DB5,DeAg Mclaren MP4-23,Hummer,Hayabusa,CB750,Harley Fatboy, Countach,Mustang,C57, Pocher Ducati,Hachette Tiger tank, Tamiya CB750F,
#36 Posted : 30 August 2018 19:39:49
Groups: Registered, Forum Support Team, Administrators
Great work Graham ThumpUp Very informative diary too
Keep it up
Regards Gray
Current Builds: 1/12 Spitfire, 1/90 Santisima Trinidad, 1/60 Sultan Arab Dhow, 1/72 Airfix Vulcan, Ugears U9 Grand Prix Car
pemberg
#37 Posted : 30 August 2018 20:25:21
Nice work, looking great.
Graeme
2 Pages <12
