 Rank: Pro  Groups: Registered
Joined: 07/06/2013 Posts: 150 Points: 455 Location: New Zealand
Well, I made the move on the planking and I must say it has gone very smoothly. Something I have noticed is, in some places the decking goes a little beyond the ribs or it is set back a little.Not a biggie though. One thing I have learned is the instructions can be a little confusing and not very well set out. Another thing I do is measure and double check everything. When it comes to camfering the planks I find it easier to put the plank in a small hobby vice and use a Stanley blade as a plane. It seem to give a smother and truer line than sanding. Curving the plank was something I was a little jittery about,but I find that using my soldering iron in a vice does the trick. Because of the thickness of the plank the heat of the iron doesn't really matter. Speaking of the plank thickness I do feel that the planks could have been a little thinner than they are. Just saying. Hope to have some pics next update.
