4 Pages <1234>
Marsot Sky Drone Build Options
Marsot
#41 Posted : 01 September 2015 14:32:21
Build on Hold
Unfortunately I have had to place my build on Hold as I am still awaiting the delivery of 2 Clockwise (CW) Rotor Arms to replace the (CCW) Arms supplied so for.
I have built up to Pack 5 and have Packs 6 & 7 awaiting installation.
When the correct Rotor Arms are delivered I will have to disassemble the first rotor Arm and re-build with the Clockwise Rotor Arm.
The build will continue as soon as I receive the correct Arms.
______________________________________________________________________________________________
Building: Sky Drone, HMS Victory, Mary Rose
Wishlist: Spitfire
http://www.sotheran.com
Marsot
#42 Posted : 22 September 2015 17:52:40
We are off again!! Love
The 2 replacement Clockwise Rotor Arms have arrived - many thanks to Mt T!
First I have to rebuild the Front Left Rotor Arm assembly - using the replacement CW Rotor Arm. ( I can't hardly believe that it was a supply error way back in Pack 1)
The picture below show the correctly reassembled Front Left Rotor Arm (Clockwise)
Marsot attached the following image(s):
Wishlist: Spitfire
Marsot
#43 Posted : 22 September 2015 18:01:06
Stage 23 - Fixing the front left Arm
Wishlist: Spitfire
#44 Posted : 22 September 2015 18:01:24
Glad your now sorted BigGrin
Marsot
#45 Posted : 22 September 2015 18:30:51
Stage 24 - Fixing theSecond Electronic Speed Controller
This is an easy job - I'm using White Tack instead of double-sided tape - no problems.
Wishlist: Spitfire
Marsot
#46 Posted : 22 September 2015 18:36:31
Stage 26 - Attach the rear left arm
This uses the rear left arm assembled - way back - in Stage 19
Wishlist: Spitfire
Marsot
#47 Posted : 22 September 2015 18:40:36
Stage 27 - Connect Electronic Speed Control wires
Connect the two ESC's to the 2 fitted rotor arms.
Wishlist: Spitfire
#48 Posted : 22 September 2015 20:55:24
Hi Marsot BigGrin
Good to see you back on this one, coming on nicely.Cool
Marsot
#49 Posted : 22 September 2015 23:56:50
Stage 28 - The Front Right Rotor
Preparation of the drive unit and anti-clockwise rotor.
Wishlist: Spitfire
Marsot
#50 Posted : 23 September 2015 00:00:40
Stage 29 - Hinges and sidebar
Fitted a hinge to rotor arm, added right side sidebar and red orientation ball to the undercarriage.
Wishlist: Spitfire
Marsot
#51 Posted : 23 September 2015 00:06:14
Stage 30 - Front Right motor
Prepared the anti-clockwise motor for the front right rotor arm and reapplied the anticlockwise rotor blade (CCW).
Wishlist: Spitfire
davetwin
#52 Posted : 23 September 2015 00:07:45
Nice job Marsot, starting to look really cool Cool
Marsot
#53 Posted : 23 September 2015 00:09:22
Stage 31 - 3rd Electronic Speed Control (ESC)
Wishlist: Spitfire
Marsot
#54 Posted : 23 September 2015 11:58:34
Steve - thanks for kind comments - I too cannot wait till she's flying - hopefully this will be January/February!
Wishlist: Spitfire
Marsot
#55 Posted : 23 September 2015 12:01:07
Dave twin - thanks, i'm really enjoying the build - can't wait to fly her! BigGrin
Wishlist: Spitfire
Mekon
#56 Posted : 23 September 2015 13:43:12
Great to see it back on track Marsot.
I am hoping to receive my correct parts through before the weekend so I can also re-start
Marsot
#57 Posted : 14 February 2016 16:26:24
Stages 32 - 33
In these stages we test the rear right rotor and the front and rear chassis.
This is what the chassisparts look like before test-fit
Wishlist: Spitfire
Marsot
#58 Posted : 14 February 2016 16:41:08
Stage 35 and 36
We attach the front right rotor arm:
Wishlist: Spitfire
Marsot
#59 Posted : 14 February 2016 16:47:13
Stage 37
In this stage we position the LED board in the chassis and fix three LED connectors from the three rotor arms - installed so far.
Wishlist: Spitfire
#60 Posted : 14 February 2016 17:10:14
So good to see you still up for this one.
Cool Cool Cool Cool
Keep the updates coming and maybe a video of the first flight?
4 Pages <1234>
This page was generated in 0.276 seconds.
