WildRover D51 build Options
WildRover
#1 Posted : 20 February 2016 17:11:43
Latex gloves - check
Epoxy glue - check
Superglue gel - check
White vinegar and soapy water - check
Mr Metal primer - check
Let's get it on....oh, ok, lets at least soak the first lot of parts anyway!
(Question, do ALL the parts have a protective film on - ie am i going to have to degrease everything, or just the brasswork - thinking along the lines of the underframes, will they need degreasing too, as surely the vinegar will damage the paintwork on it?)
Completed: Earth, Moon, Sun Orbiter
Build a Model Solar System
Under Constuction: HMB Endeavour
HMS Victory
Mitsubishi Zero
Tiger Tank
D51
#2 Posted : 20 February 2016 18:24:36
I only degreased the parts I was painting, not the underframe.
I used simple green as my degreaser.I also used 2000K automotive epoxy paints so I had no adhesion issues.
WildRover
#3 Posted : 26 February 2016 20:42:36
The degreasing station begins - as does the long road to train euphoria!
(Excuse the mess in the kitchen! Was a last minute idea to do it in there)
HMS Victory
Mitsubishi Zero
Tiger Tank
D51
WildRover
#4 Posted : 04 March 2016 15:18:26
HMS Victory
Mitsubishi Zero
Tiger Tank
D51
#5 Posted : 04 March 2016 16:53:48
Nice to see it moving along well. Hope you are enjoying your build.
COMPLETED: Porsche 911
#6 Posted : 04 March 2016 19:16:14
Off to a great start, looking good.....Cool Cool
alemo
#7 Posted : 05 March 2016 11:31:28
I enjoyed this build because of the different techniques involved working with metal instead of wood.
You have a good approach and I'm sure it will all work very well.
Alec
Adapt, improvise, overcome.
WildRover
#8 Posted : 06 March 2016 22:45:47
Loving the build, can't believe how bloody HEAVY it is though! Blink
Had a productive weekend, luckily the mrs was in a "do nothing" mood so I got loads done!
Undercarriage section, complete so far (though I'm sure there will be more bits to be added to it later! Cool )
Decided to do the tender for the next part, this is the start of the bracing - you wouldn't normally see this once built!
HMS Victory
Mitsubishi Zero
Tiger Tank
D51
WildRover
#9 Posted : 20 March 2016 15:18:31
HMS Victory
Mitsubishi Zero
Tiger Tank
D51
#10 Posted : 20 March 2016 19:19:48
BigGrin Looking goodCool
WildRover
#11 Posted : 20 March 2016 23:22:53
Cheers...well this is the tender done pretty much...bit of water marking on the metal, but I'll have that polished out before i lacquer it..
HMS Victory
Mitsubishi Zero
Tiger Tank
D51
greyhawk
#12 Posted : 21 March 2016 09:58:10
This page was generated in 0.117 seconds.
