5 Pages <12345>
Michaels Victory Cross-section Options
michael.rolph
#41 Posted : 25 July 2017 23:18:36
Orlop details
The sea chest were built around a core of balsa wood to make them sturdier. The hammocks were rather fiddly(i'm not looking forward to rigging my SOTS). The pump pipes were assembled and painted. I've also started the assembly of the cannons.
michael.rolph attached the following image(s):
michael.rolph
#42 Posted : 25 July 2017 23:20:34
Orlop fitting
The sea chest and hammocks have been fitted. The pipes have been placed and the remaining deck supports added.
DaDokta
#43 Posted : 26 July 2017 05:57:29
Coming along nicely!
Greetings,
Walter
Present builds:
HMS Victory X-section
On the shelf:
Completed builds:
#44 Posted : 26 July 2017 13:49:06
Looking great Micheal great work pal.
Chris Cool
On the bench
#45 Posted : 26 July 2017 17:44:23
Now that is looking good Michael, very nicely done....Cool Cool
#46 Posted : 26 July 2017 18:22:08
Coming along well.
The hammocks look a bit fiddly, but well worth the effort.
Cool Cool Cool
Keep up the good work. BigGrin
#47 Posted : 26 July 2017 18:38:07
#48 Posted : 26 July 2017 18:38:25
#49 Posted : 26 July 2017 20:29:02
Some lovely details on this BigGrin nice work Michael.
pemberg
#50 Posted : 26 July 2017 20:45:09
Great job Michael, coming along nicely.
Graeme
Garth
#51 Posted : 06 August 2017 15:59:26
Active Service Medal: 500 post active service MedalTurquoise Medal: Turquoise Medal for model making know-how contributionBuild-Diary Medal: Build-Diary Medal of HonourOutstanding Build: An award for an outstanding build
Hi Michael,
Progressing nicely. Looking forward to your next update.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
michael.rolph
#52 Posted : 15 August 2017 18:56:18
Time for another update.
Thanks everyone for the kind comments and encouragement
Lower gun deck
I added the deck planks to the lower gun deck. Once I got to the raised section in the centre I discovered that the elm tree pumps were too low and I had to boost them up by adding scrap pieces into the holes in the hold. This caused two of the pumps to break at the bottom connection so I had to re-glue them in place.
The only issue I have with the deck itself is that the chaulking lines don't really stand out once the deck stain has been added.
Finally the hull sides supports were added and painted.
michael.rolph
#53 Posted : 15 August 2017 18:57:48
Cannons and rigging
Construction of the cannons went well except for adding the nails into the barrel supports. I ended up cutting the heads off the nails and glueing them into place.
Making the the blocks took a while most of the time taken was trying to tread the string through the blocks. I ended up widening the holds slightly and stiffening the ends of the string with PVA glue.
I had trouble getting a good paint coverage on the brass parts so I decided to leave them brass. I will have to buy some blackener for the future.
michael.rolph
#54 Posted : 15 August 2017 18:58:56
Pumps
The pumps were placed on the platform directly over the elm tree pumps. One set appeared too close to the mast hole so I had to relocate them slightly, but there still doesn't seem to be alot of room for the mast collars to be fitted.
michael.rolph
#55 Posted : 15 August 2017 19:00:01
Tables
michael.rolph
#56 Posted : 15 August 2017 19:01:32
Lower gun deck supports
The deck beams were added and the four support posts fitted.
I accidentally glued the roller fairleads to the wrong posts. When I removed them one of the rear blocks snapped or pulled out of the ring. I had to cut the block out, tie on a new section of string and then re-tie the block and ring.
michael.rolph
#57 Posted : 15 August 2017 19:04:30
Does anyone know why some file attachments only appear as download links?
GilShapley
#58 Posted : 15 August 2017 19:21:52
Here is a hint to help with the threading of blocks. I used the super glue trick at first but "borrowed" one of my wife's needle threaders and used it to pull the thread through. Works a treat, just make sure the holes in the blocks are clear.
I was able to get 10 threaders from EBay for just a few quid
Current Build:- Model Airways Fokker DR1 :-)
[color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]Building RB7,OcCre Missippi River Boat
#59 Posted : 15 August 2017 20:20:55
Michael
Its your file size. Anything over 200k in file size creates a download rather than viewable image.
More details can be seen here
http://forum.model-space...t.aspx?g=posts&t=244
michael.rolph
#60 Posted : 16 August 2017 08:37:57
Thanks Tony, I have fixed the images. The JPEG compression was set to 100% so it wasn't compressing the file sizes
Guest (3)
5 Pages <12345>
This page was generated in 0.244 seconds.
