Adding the 100A parts Options
#1 Posted : 22 October 2017 18:50:55
Here are the parts labelled from A to H
#2 Posted : 22 October 2017 18:51:38
This first picture shows where parts A & B are applied. Please note, that part B needs to be attached reverse to what the picture on the instruction that came with issue 100A is shown. Please see the picture for reference.
#3 Posted : 22 October 2017 18:52:14
This second picture is for parts E & F. Note, part E is to be applied with the small triangular piece facing downwards. Part F is attached next to it as shown.
#4 Posted : 22 October 2017 18:52:51
The third picture shows parts C & D. These are very straight forward, apply as shown.
Applying parts G & H will follow shortly.
#5 Posted : 05 November 2017 14:57:38
Part “G” fits as shown.
Part “H” is a replacement for that supplied in Issue 94. You will notice there is little difference between these parts, so only replace this is you feel it is necessary, personally I will be leaving the original piece in place as it does not deter from the overall look of the model.
Should you decide to do so, then please take care removing the original piece, if the part has already been fixed in place.
This page was generated in 0.113 seconds.
