Help with issue 80 Options
alex4wwl
#1 Posted : 30 January 2018 11:04:32
Hi,
I am busy with issue 80, the mag tells you to connect numbers 1,2,3,4 and 5 from the previous build issues,
I don't have 5 wires already built,
I have the 2 pedal switches and the dash switch, I also have the wires coming from the battery box, but it is unmarked,
Can anyone tell me the number of the wire from the battery box and where the 5th wire comes from?
Much appreciated,
Alex
#2 Posted : 30 January 2018 13:06:09
Hi alex
With Issue 80 you are supplied with washer fluid reservoir, circuit board, 10 cables numbered 1 to 10 and two screws. The above listed are the cables to be fitted to the circuit board and then attached to the front inner wing.
As for your missing wires below are the cables already fitted with issue numbers and connection numbers.
Issue 45- accelerator switch cable 01, brake switch cable 02.
Issue 63- Horn switch cable 03.
Issue 72- on/off light switch cable 04.
Issue 76- battery box cable 05.
cable 06 is the speaker cable on the inner wing next to the circuit board that will leave four cables from the front and rear lights to be attached.
I would think that you horn switch is the missing cable and that the battery box should have been supplied with its number attached but may have fell off somewhere during assembly.
alex4wwl
#3 Posted : 30 January 2018 14:59:16
Hi Arpurchase,
I am missing issue 59, its on back order, the hooter cable is indeed part of it,but unable to fit till I get 59,
Thanks for the info on number 5
Label is definately not there,
Much appreciated,
Regard,
Alex
This page was generated in 0.079 seconds.
