Joined: 26/05/2014 Posts: 754 Points: 2,307 Location: East Sussex UK
Those belay pin racks look great Alan, fiddly and tedious but worth it. Regards Paul Building: DelPrado HMS Victory. DeAgostini HMS VictoryCollecting: DeAgostini Sovereign Of The Seas.
Thanks for looking in and your comments. appreciated...  .. In this stage we assemble another 16 gun carriages. These are assembled in exactly the same way as already outlined in stage 18, therefore am not going to repeat the process here. This brings an end to stage 42, next stage we go through the process of fitting the gun carriages in place. Until then, happy building all.... Regards Alan Gandale attached the following image(s):
HI Alan. Looking fantastic. Lots of pin rails on her. Look forward to seeing your progress. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks Ian, appreciated as always.... Regards Alan
Looking great Alan, excellent work.
Graeme
 Rank: Super-Elite        Groups: Tech Support, Forum Support Team, Moderator, Registered, Official Builds, Global Forum Support Joined: 11/11/2009 Posts: 3,402 Points: 10,250 Location: Bâe Colwyn, Wales
Nice work Alan. Coming along great.
Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Very nice Alan, and yes i'm still wearing my sunglasses when i look at this build Building: DelPrado HMS Victory. DeAgostini HMS VictoryCollecting: DeAgostini Sovereign Of The Seas.
Thanks to all who looked in and for your kind comments, appreciated.... Regards Alan
Looks great the cannons are Very striking Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 20/10/2016 Posts: 3,950 Points: 11,886 Location: Wiltshire
I like the look of all those cannons lined up Alan. Great work! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Thanks guys, appreciated.... Regards Alan
 Rank: Semi-Pro Level 1  Groups: Registered
Joined: 20/05/2018 Posts: 69 Points: 210 Location: portsmouth
hi. i have started my build and will shortly be starting the first set of planking, it says in the instructions to glue the planks but does not mention pins, i see you pinned yours and that there are pins in the kit, should i use these pins for the planking. Im getting sweaty palms at the prospect of the planking as thats where i seem to fail lol
pfcdre wrote:hi. i have started my build and will shortly be starting the first set of planking, it says in the instructions to glue the planks but does not mention pins, i see you pinned yours and that there are pins in the kit, should i use these pins for the planking. Im getting sweaty palms at the prospect of the planking as thats where i seem to fail lol Pins provided with the kit are not for planking purposes and will be required later in the build. The pins I used were from my own stock. There are many other ways of securing the planks and you may find this topic useful... https://www.model-space....s-victory-full-kit.html
If you would prefer to use brass pins then they are available in various sizes from this supplier https://www.cornwallmode...p;TB=O&ACTION=Go%21
I would also recommend you pre-drill the pin holes first to help prevent the wooden strips or frames from splitting... One of my favourites is round headed map pins however, you should consider these as one time use only simply because the head of the pin is likely to come away when withdrawing the pins. Hope this helps.. Regards Alan
Lovely work Alan, you can definitely see those coming. I’m surprised they didn’t shout,” you’ve been tango’d” Mark
Gandale wrote:pfcdre wrote:hi. i have started my build and will shortly be starting the first set of planking, it says in the instructions to glue the planks but does not mention pins, i see you pinned yours and that there are pins in the kit, should i use these pins for the planking. Im getting sweaty palms at the prospect of the planking as thats where i seem to fail lol Pins provided with the kit are not for planking purposes and will be required later in the build. The pins I used were from my own stock. There are many other ways of securing the planks and you may find this topic useful... https://www.model-space....s-victory-full-kit.html
I would also recommend you pre-drill the pin holes first to help prevent the wooden strips or frames from splitting... One of my favourites is round headed map pins however, you should consider these as one time use only simply because the head of the pin is likely to come away when withdrawing the pins. Hope this helps.. Regards Alan thanks for the advice Alan, i need to order a few bits so i will order those pins too. I think i will take your earlier advice and set aside my Hermione build and start my victory to get into the planking side of things. your build of Hermione looks fantastic, im looking forward to the day i can take on projects with confidence.many thanks Andre
pfcdre wrote:Gandale wrote:pfcdre wrote:hi. i have started my build and will shortly be starting the first set of planking, it says in the instructions to glue the planks but does not mention pins, i see you pinned yours and that there are pins in the kit, should i use these pins for the planking. Im getting sweaty palms at the prospect of the planking as thats where i seem to fail lol Pins provided with the kit are not for planking purposes and will be required later in the build. The pins I used were from my own stock. There are many other ways of securing the planks and you may find this topic useful... https://www.model-space....s-victory-full-kit.html
I would also recommend you pre-drill the pin holes first to help prevent the wooden strips or frames from splitting... One of my favourites is round headed map pins however, you should consider these as one time use only simply because the head of the pin is likely to come away when withdrawing the pins. Hope this helps.. Regards Alan thanks for the advice Alan, i need to order a few bits so i will order those pins too. I think i will take your earlier advice and set aside my Hermione build and start my victory to get into the planking side of things. your build of Hermione looks fantastic, im looking forward to the day i can take on projects with confidence.many thanks Andre I think you're making the right decision Andre, building the Vic first will give you a good insight on the process for ship building. The Hermione is certainly not a kit for the novice.... Regards Alan
Looking to move this one forward a little and this stage has us fitting and rigging the 16 cannons on the upper deck. Stage 19 outlined in detail the process of fitting and rigging the cannons so it is not my intention to repeat the process here. This brought an end to stage 43. More soon.... Regards Alan Gandale attached the following image(s):
 Rank: Pro  Groups: Registered
Joined: 30/08/2012 Posts: 338 Points: 887 Location: London
Excellent work, looks like it will be a lovely ship when built. Lucky you’re in Aberdeen, it’s too hot to even think of doing any modelling down here
Very nice Alan Very hot in the Midlands too. When I`ve opened a jar of paint it starts skinning over within seconds. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Rank: Elite      Groups: Registered, Official Builds Joined: 10/05/2010 Posts: 2,339 Points: 6,716 Location: Lincolnshire
Cracking build Alan, but then that’s your usual standard.
