Joined: 26/05/2014 Posts: 206 Points: 621 Location: Swellendam, RSA
I have been away for a while and recovering from last weekend which was a long weekend for us. Ok, hindsight is 20/20 vision. I am busy with the running body and the amount of times that I must take parts off to fit 1 part boggles the mind. I mean, take the nose section off for the second time to fit a spacer!! Somewhere along the line somebody was was not thinking as you have to unscrew and screw back again into plastic. It is so easy to strip the holes. I would have split the build between static body and racing body. But then again people are waiting for the parts, so this is a difficult decision. It's not the fall that kills you, it's the sudden stop
Building: Bismark, 2.5m wingspan glider
Guest (5)
