Custom metal sizing.
Looking for recommendations to fabricate a 15 mm x 5 mm hollow square (tube). Please post or PM me.
thank you.
 Not sure what you are trying to make but you could use 1 mm wood sheet or plywood to fabricate your box or for something more sturdy you could use brass sheet to make it. Although the brass sheet method would need to be soldered or brazzed to give it strength. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
