6 Pages 123>»
Tornado GR4, ZA458,'DG','Mean One', Operation Telic Tonkas dio. Options
#1 Posted : 22 October 2018 12:50:54
Last year of the Tornado - competition entry
Operation 'Telec' [ Greek for Purposeful ] or as one RAF wag put it 'Tell Everyone Leave Is Cancelled took place in 2003 with 100 plus RAF aircraft being involved and 32 Tornado's. The operation bases were firstly situated in Qatar and Kuwait before all the aircraft were moved to Kuwait the last Tornado being withdrawn in 2009.
Now on with the kit and parts, I got the kit from Jadlam at a very decent price but as you can see its a German ECR Tornado so the decals cant be used and it will need converting to a RAF GR-4 config. The kit is up to Revell's usual standard with some nice panel lines and there usual instructions. To do the conversion resin aftermarket cockpit, tailpipes and wheels came from Aires and Armory For the missing pods and bombs flightpath replacements were used along with there conversion and flaps sets. There are reports that the revel undercarriage is a bit weak so aftermarket metal ones will be used. Eduard masks for the cockpit glazzing and the operation Telic decals aquired. Last of all lead weight for the nose to stop it becoming a tail dragger.
A dio base has been aquired along with an RAF dio, ground power unit and bording ladder sets from Flightpath.
SAM publications also do a great book with lots of pictures called the Panavia Tornado.
Good luck to all who are entering this comp.
#2 Posted : 22 October 2018 13:27:43
This should be good, I look forward to this. Some nice extras as well.
#3 Posted : 22 October 2018 14:04:59
Look forward to seeing this one come together AndyCool BigGrin
#4 Posted : 22 October 2018 14:08:18
Blimey, a Tornado and then some Laugh LOL
Good luck in the comp Cool
#5 Posted : 22 October 2018 16:43:26
Look forward to this build. There are plenty of extras on your bench.
ChrisCool 😎
On the Bench
#6 Posted : 22 October 2018 19:01:59
Nice set off goodies there AndyBigGrin look forward to seeing them come together.
#7 Posted : 22 October 2018 19:42:26
Great choice Andy, and good luck in the comp ThumpUp
#8 Posted : 23 October 2018 07:26:03
BigGrin Thanks for looking in and your comments guys 5 of us in it so far starting to get interestingBigGrin Drool Cool
#9 Posted : 01 November 2018 18:05:02
BigGrin Hi all
Started with the cockpit resin set, lots of casting blocks to remove and then some trimimg to get it to fit the front fuselage halves. The front wheel well was also fixed in position to aid in the fitting of the cockpit. Its easyer to fit the cockpit side rails directly to the fuselage halves rather than glueing them to the cockpit as you dont get any gaps to fill this way. The two cockpit consuls had there etch footpedals added. Once all fitted in a dry test run the cockpit floor was sprayed with under coat as were the other parts then the cockpit floor was sprayed dark grey. lots more painting and detail to be added.
More soon.
AndyCool
#10 Posted : 01 November 2018 18:08:30
BigGrin Off to a great start Andy ThumpUp
#11 Posted : 01 November 2018 19:29:53
Good to see you up and running AndyBigGrin looks good.
mogwai
#12 Posted : 02 November 2018 21:32:47
Hi very nice start ,look forward to more.cheers mick.BigGrin
#13 Posted : 03 November 2018 09:05:58
Nice start Andy. Look forward to more pictures.
On the Bench
#14 Posted : 03 November 2018 09:13:59
Nemesis
#15 Posted : 03 November 2018 13:02:00
As always top work Andy, this will be one to follow!BigGrin Cool
#16 Posted : 04 November 2018 08:36:56
BigGrin Thanks for looking in and your comments NemCool
#17 Posted : 04 November 2018 14:24:33
Looking very good Andy.
Silent_Running
#18 Posted : 04 November 2018 14:49:38
Lovely start Andy, looking forward to seeing more! Cool
#19 Posted : 04 November 2018 17:53:14
BigGrin Thanks for looking in and your comments both of youCool
#20 Posted : 04 November 2018 18:04:45
BigGrin Hi all
The resin cockpit has been painted and fitted into the fuselage and then the two halves were joined together. The nose radar was painted and assembled but before it was glued into the nose lead weights were added to the space in the nose to stop it becoming a tail dragger.
Next the etch for the canopy was prepared and added to the kit parts makes the canopy look quite impresive.
The wings as you can see need a fair amount of butchery so the flap, aileron and spoilers etch kit will fit but its easy enough to do with care.
Last of all today the resin tail motors were prepared and then dry fitted into the tail section. These will be given the Alclad treatment in the next few days.
More soon.
AndyCool
6 Pages 123>»
This page was generated in 0.886 seconds.
