HMS Surprise 12/24 months or Full Kit. Options
#1 Posted : 03 November 2018 19:55:19
Groups: Registered, Administrators, Global Forum Support, Tech Support, Official Builds
Get your HMS Surprise in 12/24 monthly instalments or Full kit.
Key Features of the HMS Surprise:
Laser cut keel and all main frame parts, High-quality planking mahogany, walnut and lime woods.
High-quality fittings in white metal burnished or in real die-cast brass.
Stitched sail set and rigging threads.
Pre-finished high-quality display base with name plate.
Overall Dimensions
Scale: 1:48 | Length: 1334 mm (52.75") | Height: 950 mm (37.5") | Beam: 480 mm (18.5")
Also available from the Modelspace store is this practical set of basic ship modelling tools from Artesania Latina at an additional cost.
This tool kit includes:
Nº1 modelling knife, Pin-nailer, Archimedes mini-drill, Side cutter pliers, Snip Scissors and Sanding block:
https://www.model-space....-modelling-toolbox.html
Also Keep your tools and consumables in perfect order with the modellers workstation, it has many compartments and drawers to keep your tools and parts together.
https://www.model-space....elling-workstation.html
Also the Paints & Tools Organiser is the perfect compliment to the Modellers Workstation:
https://www.model-space....nd-tools-organizer.html
(modelling items not included)
Huckboss
#2 Posted : 25 November 2018 00:02:31
Hi there. I was wondering if you had some info on how to install the rudder hinges on HMS Surprise (Artisania Latina). Im up to this part but the instructions are rather difficult to follow and they have no good pictures of the rudder assembly at all.
Thanks.
#3 Posted : 25 November 2018 00:18:14
Hi Huckboss. Welcome to the Forum.
Here is a link to mine. See if the pictures help in any way onto it being installed. follow the build through to the next page. If you need any more help don't hesitate to ask ,just open a new topic in the Surprise discussion .
https://forum.model-spac...s&m=38336#post38336
This page was generated in 0.126 seconds.
