4 Pages «<234
micks E type jag build Options
#61 Posted : 04 November 2018 23:16:34
All looking good Mick, great to see you're now up to date....Cool Cool
#62 Posted : 05 November 2018 07:41:51
Nice work, you are obviously getting to be an expert on these.
#63 Posted : 05 November 2018 17:03:48
Good stuff Mick. Cool
Only problem with catching up is waiting for the next parts. Hope your next parts are due soon. Blink
turilacoste
#64 Posted : 06 November 2018 05:02:03
mogwai wrote:
Hi as regarding the engine painting I just taped off the bits I not want painting. And prepped the rest with bit of wet an dry paper before painting to give a key to the paint,then it was just brush applied with tamiya semi gloss black, then added the gold to the ports, hi Roy I'll be pinching some your ideas as I intend to carpet with dolls house carpet,and will be doing the leather trim to, thanks to all who looked in cheers mick.Blink
For the preparation of painting, do you think a chemical paint remover can be used instead of paper?
mogwai
#65 Posted : 06 November 2018 11:48:48
Hi personally I'd not use it as it may eat away at the plastic and destroy the engine ,cheers mick.BigGrin
turilacoste
#66 Posted : 07 November 2018 06:31:54
Thanks, Mick.
So far I have received only the first issue and looking at your photos I was convinced that all the pieces of the engine were made of metal as the cylinder head I already own.
Salvatore
SLowner
#67 Posted : 19 November 2018 18:24:24
Salvatore,
I used a product called Modelstrip which is safe to use on plastic - it is a paste and you put the parts in a sealed bag overnight before washing off with water. I seem to remember that I sprayed the whole block satin black and then masked the area around the copper core plugs using masking tape punched out using an ordinary paper punch. Effect was much better than hand-painting the copper.
When you get to attaching the wheels to the hub, there is an important tip which I would like to share with anyone who is at an early stage like yourself.
#68 Posted : 19 November 2018 20:17:37
Looking really good so far.
This kit just has SO much scope for upgrades.
Have fun with it.
mogwai
#69 Posted : 19 November 2018 20:19:36
Hi that's useful info ,I'm having no issues with attaching wheels ,but any tips would be welcome ,but be best if you put it in the jaguar discussion section ,rather than a individual diary ,more people would find it there ,cheers mick.
SLowner
#70 Posted : 27 November 2018 12:33:31
Mogwai,
I found the screws which hold on the wheels were very hard to tighten and, when it came to removing them, the thread had disappeared and the screws were too slack to tighten again! Solution: bought a set of 6BA taps and screws to create a proper thread and now the wheels can be taken off and put back on easily.
mogwai
#71 Posted : 27 November 2018 12:55:50
Hi good idea ,when I put screws in metal to cut thread I always put drop of oil in hole first ,this helps when cutting the thread ,so it don't tear due to dry cutting ,cut it slowly 2 turns forward one back ,I find this prevents thread stripping and leaves a nice thread in holes ,I have metric taps anyway ,cheers mick .BigGrin
SLowner
#72 Posted : 29 November 2018 18:19:54
Mick,
Your solution makes sense - coming from a largely plastic kit background, I have not encountered this problem before! Pity DeAg don't recommend your method in the instructions!
Cheers,
Steve
suedehead
#73 Posted : 01 December 2018 22:44:35
Is anyone able to build my wheels for me as I just cant get the hang of it, my patience isnt great, would be a great help please, thanks, paul
mogwai
#74 Posted : 02 December 2018 11:19:19
Hi Paul happy to help have sent you PM cheers mick.BigGrin
suedehead
#75 Posted : 09 December 2018 12:19:44
Hi there mick, sending pic of wheel over to you, paul
suedehead
#76 Posted : 09 December 2018 12:32:38
Picture of Jag e-type wheel mick, paul
suedehead
#77 Posted : 09 December 2018 12:33:52
mogwai
#78 Posted : 14 March 2019 17:50:37
Hi got few more issues of this now, so gone back a bit, took door apart and covered it suede leather, just like the look of suede, to normal leather, probably never done on a real one, so just personal preference. The door on the right done and the left as supplied. Cheers mick. BigGrin
#79 Posted : 14 March 2019 20:12:56
Nicely done MickBigGrin looks good.
#80 Posted : 15 March 2019 08:01:59
Nice work Mick, coming on nicely.
4 Pages «<234
