3 Pages 123>
Alemo's build Options
alemo
#1 Posted : 28 August 2018 11:54:04
Pack 1 arrived and in a nice Model Space box so well protected.
Parts appear to be good quality and I would not expect anything else.
Not a lot to do except fit the tank badges and join the tank parts together.
Instructions say quite specifically use the Philips screw driver however, screw type "A" is a slot head, doesn't matter because there is no choice of screw to use but later on when we have more screws I hope this will be sorted out. It would have been better to have a cross head screw as the fixing is in a recess.
Not moaning but worth pointing out.
Alec
Adapt, improvise, overcome.
alemo
#2 Posted : 09 November 2018 15:36:49
Now up to stage three.
This is a large model but very detailed, assembly was straight forward and instructions very clear once I downloaded on my wife's MacBook Air as problem with iMac, details in site problem forum.
One or Two holes needed clearing to accept screws but otherwise ok.
Alec
#3 Posted : 09 November 2018 16:42:28
Nice start, looking good.ThumpUp
#4 Posted : 09 November 2018 17:11:11
BigGrin Looks good Alec ThumpUp You're right, she's very large and heavy but that's how you get all that detail BigGrin
Keep it coming
regards
Gray
mogwai
#5 Posted : 09 November 2018 21:33:37
Hi looks good Alec ,some nice detail in this kit,cheers Mick.BigGrin
#6 Posted : 10 November 2018 00:47:56
Progressing nicelyBigGrin its an impressive kit.
alemo
#7 Posted : 10 November 2018 10:17:30
Alec
#8 Posted : 10 November 2018 18:37:43
Nice start Alec, great kit and up to the your usual high standers.
Trev.
pemberg
#9 Posted : 10 November 2018 19:35:54
Great start Alec, looking good.
Graeme
MasterRich
#10 Posted : 17 November 2018 15:38:58
When did you get your 3rd pack? Still waiting for mine
alemo
#11 Posted : 18 November 2018 11:03:09
Around 7th Nov
Alec
MasterRich
#12 Posted : 18 November 2018 20:50:15
ok thanks I'll call them tomorrow to find out what has happened :)
alemo
#13 Posted : 09 December 2018 13:23:37
Hi Everyone,
Pack 4,
Exhaust components, a little like the metal puzzles we had as children but a lot heavier.
I found that the Lambda probes were a too tight a fit and wouldn't stay fully home, so I scraped the finish off the locating pin which allowed it to go fully home but then required adhesive but they are looking better that way.
Worth checking which way around the springs look best as there are differences in the angles of the loops, I felt happier with adhesive on the spring plate pins as I'm not sure about access later in the build should one become loose.
The head and cover is simple as is the dashboard.
Alec
#14 Posted : 09 December 2018 20:05:21
All looking good Alec, very nice update to your build....Cool Cool
#15 Posted : 10 December 2018 00:01:55
Another very nice informative update.
Well Done.Cool Cool Cool
#16 Posted : 10 December 2018 00:59:44
Nice update AlecBigGrin I like how the exhaust system looks on this.
alemo
#17 Posted : 26 January 2019 15:21:07
Pack 5 arrived a little late but no problem.
Parts are up to usual standard and only slight adjustment to the small bracket that slides into end of radiator where some flashing required removing to enable a nice fit.
The air box parts are stored until required later.
Alec
#18 Posted : 26 January 2019 17:34:47
Nicely done Alec.
#19 Posted : 26 January 2019 20:35:59
Looking good Alec ThumpUp
Have to say, so far, this is a great kit Love
#20 Posted : 27 January 2019 11:05:49
Hi Alec,this kit look's good model bikes are one of my favorite's and with the high standard of your build this will make a great display.
Trev
3 Pages 123>
This page was generated in 0.159 seconds.
