5 Pages <1234>»
R2-D2 Battery & Test charger Information Options
Michaeljf1980
#21 Posted : 06 December 2018 14:33:52
These are the batteries I have purchased, are these ok ? https://eu.nkon.nl/sanyo-18650ga-button-top.html
#22 Posted : 06 December 2018 14:44:29
Groups: Registered, Administrator, Administrators, Global Forum Support, registriert, Official Builds, Moderator, Tech Support
Unless I missed it, I can’t see any mention of unprotected?
coldsweat
#23 Posted : 06 December 2018 14:48:37
Rank: Amateur level 2
These seem to be protected, so are unsuitable.
semaj
#24 Posted : 06 December 2018 14:51:37
Tomick wrote:
[quote=Michaeljf1980]These are the batteries I have purchased, are these ok ? https://eu.nkon.nl/sanyo-18650ga-button-top.html[/quote] Unless I missed it, I can’t see any mention of unprotected?
They look like protected cells to me. They have the extra ridge at the positive end which is where the protection circuit is usually located
[center]building: R2D2
Building: Red Bull RB7 RC kit
Michaeljf1980
#25 Posted : 06 December 2018 15:03:50
It’s at the bottom of the page, under additional information
#26 Posted : 06 December 2018 15:09:26
Indeed it does say unprotected in the spec but the photo seems to be that of a protected cell. Might be worth an email to confirm 100%
figuerres
#27 Posted : 06 December 2018 15:24:36
its really amazing just how this battery has so many versions but they all refer to it by one common number!!!
also it seems like 95% of the "button top" are also "Protected"
and about 95% of the "flat top" are "Unprotected"
*IF* they had went with flat top i think this battery thing would be less of a hassle.
the only tiny gain is in identifying the + / - ends of the cell i think....
semaj
#28 Posted : 06 December 2018 15:44:39
The number 18650 denotes the size of the battery - 18mm diameter, 65.0mm long. And yeah it is super confusing with all the different varieties - protected, un protected, button/flat/nipple top, different power (amp) ratings, different capacity (mah). Total minefield. And not all of them even meet anywhere near the specified capacity or power ratings. Some brands are utterly dreadful. As a rule of thumb, if its advertised anything over around 3500mah then its an utterly false claim, as the tech doesnt exists to make them any higher than this. Also, generally, the higher the mah, the lower the power rating tends to be. What makes things more confusing is they give 2 power ratings - max continous and max pulse. Continuous is what we need to be looking at.
Michaeljf1980
#29 Posted : 06 December 2018 15:45:26
I’ve just rang the company I’ve ordered them from, he has told me they are definitely unprotected cells
figuerres
#30 Posted : 06 December 2018 21:23:52
i think this site and link may be the right ones for us:
https://www.18650battery...sung-30q-button-top.htm
Samsung 30Q 18650 3000mAh 15A -Button Top Battery - INR18650-30Q
Specifications:
Model: INR18650-30Q
Style: Button Top
Chemistry: INR
Nominal Capacity: 3000mAh
Continuous Discharge Rating: 15A
Pulse Discharge Rating: 25A
Nominal Voltage: 3.6V
Protected: No
Rechargeable: Yes
Approximate Dimensions: 18.42mm x 66.64mm (+1.80mm vs flat top version)
Approximate Weight: 48.5g
spudtrooper37
#31 Posted : 07 December 2018 07:32:49
I wish deagostini had given us 6 of those battery chargers.
Mine have taken an average of 4 hours each 🙄
Forth one should be finished soon, put another one on before work and the last when I get home.
Fingers crossed he should be working tonight 😁
Darren
Have an AWSOME day and may the Force be with you always 😉
My biggest hobby is collecting Lego Star Wars and playing the Lego Video Games
Building: Millennium Falcon
collecting: Star Wars Helmets
Pigrocks
#32 Posted : 07 December 2018 09:53:40
Specifications:
Model: INR18650-30Q
Style: Button Top
Chemistry: INR
Protected: No
Rechargeable: Yes
These are the batteries I bought.
Here is a link to them. Its a german site, but seems to be reputable.
https://www.akkuteile.de...5a-button-top/a-100807/
coldsweat
#33 Posted : 07 December 2018 09:57:28
Specifications:
Model: INR18650-30Q
Style: Button Top
Chemistry: INR
Protected: No
Rechargeable: Yes
These are the exact ones I've purchased - now I just have to wait for my final delivery as DeAG have delayed my delivery by 3 weeks for the THIRD month on the trot! #NEVERBUYINGAGAIN
stwood6
#34 Posted : 07 December 2018 14:33:00
Specifications:
Model: INR18650-30Q
Style: Button Top
Chemistry: INR
Protected: No
Rechargeable: Yes
I went here for my batteries too. Just an fYI - they carry a Panasonic battery that is rated at 3400 mAh for a few cents more. Best prices I could find, and they have a price match guarantee too.
Current Builds: R2D2, Millenium Falcon
nastro150
#35 Posted : 08 December 2018 23:11:55
These do come up when you use the unprotected filter on their site so they should be ok
coyley1
#36 Posted : 09 December 2018 14:30:35
Hi is there any reason why a battery charger different from the one supplied cannot be used? Seems daft charging one battery at a time. The volt check can still be done. Auto chargers monitor each individual battery.
#37 Posted : 09 December 2018 14:37:27
It's a balancing charger that checks each individual battery so that you have a balanced set and highlights any that are not good to use.
It is characteristic of lithium-ion batteries that the one with the worst condition will determine the performance of the whole pack. If one of the six batteries is ‘bad’ (with a very low power level, or coming to the end of its recharge cycle), it has the potential to damage other ‘good’ cells, and even the protection circuitry.
The charge/check process is only done once unless you change the batteries as the mains charger deals with charging thereafter
dragonspirit
#38 Posted : 09 December 2018 23:56:45
I still haven't got any batteries for my r2 I have looked online and there are so many different types.I waited for issue 100 for more advice on what batteries to purchase and none came.Sat here with a wonderful looking statue of r2 d2 (He is a very good model actually and have really enjoyed building him ). I have been pointed in the right direction by fellow builders on which batteries to get (they are now out of stock ).I cant understand why deagostini would leave us to source our own batteries . I would have preferred to get the right batteries from deagostini
philljwarren
#39 Posted : 10 December 2018 09:58:44
I thought the battery offer was just going to be a link to supplier, not DeAg offering the batteries for sale themselves. With that in mind, I suspect the reason its taking so long to give us the website address is because DeAg are waiting for the supplier to get enough stock ready so they dont sell out straight away.
I've waited a couple of years to get R2 ready, I can wait another couple of weeks for the battery info.
LSainsbury
#40 Posted : 10 December 2018 17:53:03
Rank: Semi-Pro Level 2
Just ordered some batteries from 18650.uk and with the discount code (thanks 18650.uk)
I know we have a charger supplied...I also have one of these:
https://www.amazon.co.uk/gp/product/B074DT3NLF/
(MiBOXER C4 Universal Smart Battery Charger 4 Slot LCD Display 18650 AA Charger for Li-ion Ni-MH Ni-Cd AA AAA AAAA C 22650 18490 18350 RCR123)
Would there be any reason that I can't use it to change the batteries for R2?
And according to CS, 98,99 and 100 are on the way...
Cheers,
Lee
5 Pages <1234>»
This page was generated in 0.163 seconds.
