Thanks guys for all your comments, always appreciated..... @Nightwisher, the detail on this build just gets better and better the further I go into it and there is a lot more detail to be added yet. This is a kit that is best taken on by those that have experience ships building ships, certainly not for a novice. So far I'm loving the build..... Regards Alan
Hi all, in this build session we will be assembling and fitting the deck banisters. From an 0.8mm brass rod, cut 12 lengths of 14mm and 12 of 8mm. Took some scrap planking strips and marked off the positions of the banister uprights using the measurements stated in the instructions, 4 banisters in total. Glued the brass lengths to the planking strips in line with the marks made in the previous step, 2 sets using the 14mm lengths and 2 sets using the 8mm. The uprights were then primed and painted black. Using 1x3mm wooden strip cut 4 lengths each of 100mm and rounded off the ends. Sanded smooth and stained with a dark wood stain. Glued these lengths to the tops of the uprights ensuring they ran parallel with the planking strip. Cut 4 lengths of netting to fit between the top rail and the bottom planking strip, leaving a 1mm gap at the bottom. When dry, cut and glued lengths of 0.5mm black rigging thread to run across the tops and bottoms of the netting. Once everything had fully set, gently removed the lower planking strips, trimmed the ends to remove excess rigging thread. Glued the banisters in position as outlined in the instructions. This build stage will be in 2 parts, in the next part we conclude with assembling the last banister and rear bell tower. Until then happy modelling all.... Regards Alan Gandale attached the following image(s):
Joined: 20/10/2016 Posts: 3,956 Points: 11,904 Location: Wiltshire
Looking really good Alan. Coming along a treat! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Thanks Phil, appreciate the comments as always...  .. Now for the second part of stage 53, the completion of the Deck Banisters. Cut 6 lengths of 2x2mm wooden strip each 14mm long and shaped the top of each strip, then cut a further 2 lengths of 3x3mm strip each 22mm long. Cut the banister frame from its fret and sanded all the edges smooth then glued the parts together as per the instructions. Removed the PE grating from its fret, cleaned up the edges and test fitted, used the PE grating to adjust the length of the posts noting that the grating has a slight curve to its bottom edge. Took the bell tower top, removed any burrs and primed ready for painting. Painted the bell tower top and the banister framing red and left to dry before gluing the top in place. Primed and painted the PE grating yellow and once dry also glued in place. Cut 6 lengths of brass rod each 8mm long, squared off the ends, primed and painted black before gluing in place. Cut 2 lengths of 1x3mm wooden strip, rounded off the ends and stained with a dark wood stain before gluing to the fitted brass rods. Assembled the bell support as in the forward bell housing, primed and painted the bell and glued the bell clapper in place. This assembly was then glued to the bell tower. Cut a further 4 lengths of brass rod each 8mm long, squared off the ends and glued in place, these act as 4 grab handles on the main frame. Finally, gave some areas a little touch up with red paint. Once the assembly was dry it was then glued in place. This brings to an end stage 53 so until next time, happy modelling all.... Regards Alan Gandale attached the following image(s):
 Rank: Elite      Groups: Registered, Official Builds Joined: 10/05/2010 Posts: 2,344 Points: 6,731 Location: Lincolnshire
 Another great update Alan
Thanks for looking in Gray, your kind comments very much appreciated..... Regards Alan
 Looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks Andy, appreciated.... Regards Alan
 Rank: Master       Groups: Registered
Joined: 08/07/2010 Posts: 1,035 Points: 3,083 Location: Thetford, Norfolk, UK
Hi Alan, what can I say that hasn't already been said. A truly great 'out of the box' build. Just hope mine will be half as good when I get around to working on her again. Happy building David
Thanks David, appreciated... Hope you get back onto your build soon, I know I for one would love to see her progressing.....  .. Thanks again.. Regards Alan
Joined: 24/02/2013 Posts: 212 Points: 632 Location: denmark
It's great work - very elegant
 Rank: Super-Elite        Groups: Tech Support, Forum Support Team, Moderator, Registered, Official Builds, Global Forum Support Joined: 11/11/2009 Posts: 3,404 Points: 10,256 Location: Bâe Colwyn, Wales
Looks Awesome Alan. You always do a nice clean tidy job. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Jens, Chris, thanks for looking in and for commenting, appreciated..... Regards Alan
Joined: 09/12/2013 Posts: 545 Points: 1,666 Location: smethwick england
Very nice decorative work ,reminds me of Japanese garden buildings Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
nightwisher wrote:Very nice decorative work ,reminds me of Japanese garden buildings Hadn't quite thought of it that way until you mentioned it, very true.... Thanks for looking in and commenting, appreciated.... Regards Alan
We move onto fitting the dummy cannons onto both sides of the hull, noting that the first and last gun port on each side is left without a cannon and these ports will be dealt with later in the build. Took 16 cast cannons, removed any burrs and imperfections before priming and painting black. Cut 16 lengths of 2mm bamboo rod, each 30mm long and glued one into each cannon, these were also painted black. Using a 2mm drill bit, drilled a hole through the gun support in each gun port ensuring the hole was centred. Finally glued a cannon into each gun port on both sides. This finishes stage 54 so until next time, happy modelling all.... Regards Alan Gandale attached the following image(s):
Joined: 23/12/2018 Posts: 318 Points: 949 Location: Illinois, USA
Now this is some serious modeling skills demonstrated. LOVE your build. Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Thanks Mark, appreciated. She is a lovely build and one I'd recommend highly especially for those with experience of ship building.... Regards Alan
Joined: 20/09/2011 Posts: 1,240 Points: 3,907 Location: Austria
Everything is looking great! Superb build!Greetings, Walter
Present builds: Solar-powered paddle Steamer (little project with my son) HMS Victory X-section
On the shelf: Italeri "Fiat Mefistofele", Italeri "Moto Guzzi California", Fokker "Red Baron", Revell Bismarck, Revell Tirpitz, Arab Dow, Stage Coach, .....
Completed builds: McLaren MP4/4, D-51, HMS Victory, GWH F-15D, St. Stephen`s Cathedral (cardboard)
Fantastic work Alan! Great attention to detail! One of the things I really love about this build is the colour scheme. It really suits! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
