 Rank: Semi-Pro Level 2  Groups: Registered
Joined: 23/12/2018 Posts: 96 Points: 294 Location: Illinois, USA
Pack 2 - Stage 13 This stage sees the installation of frame 10 and the last length of the lower deck. A 5mm x 5mm beam was glued to the lower ledges of frame 10. The joints of the lower deck sections were reinforced with scraps of 5mm x 5mm strips from below. Bulkheads B and C were covered with dark wood strips, sanded and sealed with satin polycrylic clear coat. Until next time.... Mark mwstratton attached the following image(s): Currently: Soliel Royal, Revell's 1/48 P 61 Black Widow, Deag DC-3
Under the Bench: Deag L'Hermione La Fayette,
Pack 2 - Stage 14 I started by fitting and gluing the last section of the main deck. This section was planked with 70mm sections of planking following the same pattern and the rest of the deck. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Revell's 1/48 P 61 Black Widow, Deag DC-3
Lovely progress Mark, coming along a treat.... Regards Alan
Joined: 10/05/2010 Posts: 1,451 Points: 4,073 Location: North Lincolnshire
Very tidy work Mark Well done https://m.youtube.com/watch?v=qIC4f1LE86w Current Builds: 1/12 Spitfire, 1/90 Santisima Trinidad, 1/60 Sultan Arab Dhow, 1/72 Airfix Vulcan, Ugears U9 Grand Prix Car, Valentino Rossi Yamaha YZR-M1, Italeri 1:12 Alfa Romeo 179
Thanks for the positive words, Gents. Mark Currently: Soliel Royal, Revell's 1/48 P 61 Black Widow, Deag DC-3
Pack 2 - Stage 15 This stage starts by sanding, fitting and gluing frame 11 to the false keel. Deck beams were cut and fitted across the ledges of frames 8, 9 and 10. I then Glued bulkhead A to the front of frame 8. Finally, 2 doors were added to the each of the bulkheads attached to frames 4 and 8. mwstratton attached the following image(s): Currently: Soliel Royal, Revell's 1/48 P 61 Black Widow, Deag DC-3
Pack 2 - Stage 16 The upper deck is planked, as before, with 70mm strips of planking. I sanded the planked deck and applied 3 coats of clear coat. I built the grating from a future stage and glued it in place on the stern end of the mid deck before fitting and gluing the upper deck in place. I did this for ease of assembly as the opening is under the overhang and would be more difficult in the future steps. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Revell's 1/48 P 61 Black Widow, Deag DC-3
Joined: 20/09/2011 Posts: 955 Points: 3,049 Location: Austria
Nice update!
Greetings, Walter
Present builds: HMS Victory
Builds started but currently on a hold: AKAGI, Supermarine Spitfire, Hachette U-96
On the shelf: HMS Victory Cross-section, Italeri "Fiat Mefistofele", Italeri "Moto Guzzi California", Fokker "Red Baron", Revell Bismarck, Revell Tirpitz, Arab Dow, Stage Coach, .....
Completed builds: McLaren MP4/4, D-51
She’s coming on very nicely Mark. Mark
You’re really motoring along with this build Mark. Great update. https://m.youtube.com/watch?v=qIC4f1LE86w Current Builds: 1/12 Spitfire, 1/90 Santisima Trinidad, 1/60 Sultan Arab Dhow, 1/72 Airfix Vulcan, Ugears U9 Grand Prix Car, Valentino Rossi Yamaha YZR-M1, Italeri 1:12 Alfa Romeo 179
This is coming along very nicely Mark, very nice work..... Regards Alan
Pack 2 - Stage 17 Thanks for all the kind comments to this point. This stage begins with the small deck piece that was shipped with stage 16. It was planked as before. I have chosen to paint the clear coat on the deck prior to fitting it in place. Beams were cut and glued to the front of frames 10 and 11. The deck was then fixed to those beams. Bulkhead B was attached to the front of frame 10. At this point I also decided to go ahead and install bulkhead C to the front of frame 11 and the wood trim along the front edge of the quarter deck. This completes this stage and Pack 2. Thanks again for following my build. Follow me back to the completion of my A-10 Warthog as I anxiously await arrival of Pack 3. Mark. mwstratton attached the following image(s): Currently: Soliel Royal, Revell's 1/48 P 61 Black Widow, Deag DC-3
Joined: 16/08/2010 Posts: 2,728 Points: 8,215 Location: Brighton
 Coming along nicely mark. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Rank: Super-Elite       Groups: Registered, Administrators, Global Forum Support, Tech Support, Official Builds Joined: 11/11/2009 Posts: 3,217 Points: 9,730 Location: Bâe Colwyn, Wales
Looks great Mark. I loved building mine it's a great kit to do. Chris
