Vasa Official Build Diary - Pack 8 Options
#1 Posted : 23 January 2019 23:36:57
Vasa Pack 8 – Stages 78 - 89
Stage 78 Contents: Decorations
Remove any flash or burrs from the decorations C47, C48, C49 and C50. Apply a coat of metal primer and leave to dry then follow the painting guide provided within the instructions.
Recover decoration C24 supplied with stage 77. Prepare and paint the decoration following the guide in stage 42 but using the colours outlined in the instructions for this stage.
Remove any flash or burrs from the decorations C13, C14 and C19 supplied with this stage. Apply a coat of metal primer and leave to dry, then follow the painting guide provided within the instructions
Finally, glue the arms C14 and C19 to the figure C13 and leave to dry.
This stage is now complete. Carefully store the decorations in a bag labelled with this stage number.
#2 Posted : 27 January 2019 10:33:41
Stage 79 Contents: Gallery Roof and Decorations. 
Retrieve decorations C64b, C64c, C64d, C64e, C64g, C64h, C64i, C64j and C64k from stage 72, remove any flash or burrs from each on them, then apply a coat of metal primer and leave to dry.
Identify decorations C64b, C64c, C64d and C64e. Follow the painting guide provided within the instructions to paint these decorations.
Now identify decorations C64g, C64h, C64i, C64j and C64k. Again, paint these decorations following the painting guide provided within the instructions and leave to dry.
This stage is now complete. Carefully store all these decorations in a bag labelled with this stage number.
#3 Posted : 31 January 2019 23:10:12
Stage 80 Contents: Decorations.
Retrieve decorations C65, C65a, C65b, C65c, C65d, C65e and C65f from stage 73. Remove any flash or burrs, then apply a coat of metal primer and leave to dry. Follow the painting guide provided within the instructions to paint the decorations
#4 Posted : 05 February 2019 11:51:20
Stage 81 Contents: Cannon Carriage, Wheels, Dowel, Cannon Parts and Decorations.
Retrieve decorations C66, C66a, C66b, C66c, C66d and C66e from stage 74. Remove any flash or burrs, then apply a coat of metal primer and leave to dry. Follow the painting guide provided within the instructions to paint the decorations
#5 Posted : 09 February 2019 08:21:31
Stage 82 Contents: ST Ladders, Wooden Strip and Decorations.
Retrieve decorations C67, C67a, C67b, C67c, C67d, C67e and C67f from stage 75. Remove any flash or burrs, then apply a coat of metal primer and leave to dry. Follow the painting guide provided within the instructions to paint the decorations
#6 Posted : 11 February 2019 12:02:36
Stage 83 Contents: Wooden Strips and HR Fittings.
Retrieve decorations C68, C68e, C68f, C68i, C68l, and C68m from stage 79. Remove any flash or burrs, then apply a coat of metal primer and leave to dry. Follow the painting guide provided within the instructions to paint the decorations
Smooth any flash or burrs from the lion head decorations C20, provided with stages 80 and 82, then apply a coat of metal primer and leave to dry. Follow the painting guide provided within the instructions to paint the decorations.
#7 Posted : 13 February 2019 23:19:32
Stage 84 Contents: Wooden Strips, Brackets, Eyebolts, Cannon, Cannon Carriage and Wheels.
Retrieve the ladders supplied with stage 82 and remove one of the two ST1 ladders from the fret. Fold the two sides in until they are at right angles to the central section, then carefully bed the steps of the central section up, aligning them with the notches inside the two sides.
Cut eight 8mm lengths from the 0.5x5mm wooden strips supplied with stage 82 and glue them onto the steps of the ladders.
Repeat the process to assemble a second ladder ST1, an ST3 ladder and two ST2 ladders.
Separate the cannon carriage components from the fret, smooth the edges of all the parts and paint them black. The assembly of the carriage is the same as that outlined in Stage 9 so will not be repeated here.
Remove any imperfections from the barrel of the cannon then apply a coat of metal primer and leave to dry. Paint the cannon with a bronze colour (No RAL Code) then store the cannon and the assembled carriage until needed again.
Smooth any flash or burrs from the decorations C26, provided with stage 81, then apply a coat of metal primer and leave to dry. Follow the painting guide provided within the instructions to paint the decorations. When dry, carefully store the decorations in a bag labelled with this stage number until they are needed again.
This stage is now complete. Carefully store any unused parts in a stage labelled bag.
This page was generated in 0.150 seconds.
