4 Pages «<234
D-Day 1:9 scale Triumph 3HW motorbike from the Divisional Signals, Normandie, France, 1944 Options
#61 Posted : 09 February 2019 07:45:06
BigGrin All looks good to meCool
Ritchie69
#62 Posted : 09 February 2019 09:51:12
Looking good Nemesis,
It,s nice to see this being built as I got one for Christmas (I haven’t started it yet). I just hope mine will be as good as yours. ThumpUp
Peter
Currently building - R2D2
Nemesis
#63 Posted : 09 February 2019 10:00:10
Hi all and thanks for looking in and your comments.BigGrin
Peter
Hi Peter, be prepared for some head scratching and modifications as its not the best fitting kit in the world. There is also a ton of clean up as the seams from moulding are quite extensive!BigGrin Cool
Ritchie69
#64 Posted : 09 February 2019 10:07:43
Peter
Cheers for the heads up, I will bare that in mind once I start. BigGrin
Nemesis
#65 Posted : 09 February 2019 21:51:33
I will be weathering the exhaust separately to the rest of the bike as it is easier to get all the way around it. First thing is to give it a bit of heat discolouration. BigGrin
Nemesis attached the following image(s):
mwstratton
#66 Posted : 09 February 2019 23:28:00
Solid work Nem. can't wait to see the finished model
Currently: Soliel Royal, Deag DC-3, AL L'Hermione La Fayette
Under the Bench:
Nemesis
#67 Posted : 10 February 2019 13:39:48
Thanks for looking in Mark.BigGrin
I have started on the exhaust, it's in a sort of small tutorial and will give you an idea of the different stages I used to get the rusted effect.
You want to start with the darkest colour first and build the lighter colours over the top and lastly a wash to blend it all together.
The first colour was applied with a piece of kitchen scourer lightly dabbing the paint on as you can add more but can't take away without stripping back and starting again. This technique allows you to give the paint a texture, when it is dried you can feel the rough surface. Next i use a stiff brush to apply the colours, and it needs to be a dry brush not wet. Then lightly stab the brush until you get the desired effect, again building up the colours. Make sure each stage has properly dried before moving on to the next one. Lastly I applied a wash to bring it all together, again in light coats, if you get this wrong its a pain to have to start again!. The final weathering will be done on the bike so I can get the overall finish even.Cool
#68 Posted : 10 February 2019 14:54:35
Looking excellent, nice work. Love Drool
#69 Posted : 10 February 2019 16:35:29
Superb result on the exhaustCool looks well rusted.
4 Pages «<234
This page was generated in 0.133 seconds.
