Cannon cascabel rings? Options
Milw
#1 Posted : 14 February 2019 15:37:11
I’m at the stage of constructing the visible cannons, but I’m stumped by the cascabel rings- there seems to be no good way of mounting them properly. How did everyone else deal with that?
cheers- Scott
(sorry for image link, will edit from computer to show properly!
#2 Posted : 14 February 2019 18:19:17
On mine I drilled a small hole which took its time and installed the ring. Or you could solder them on.
Starting Soon!!!!
On the Bench
Milw
#3 Posted : 15 February 2019 01:33:32
Well, that's a good use for the Dremel drill press! Did you make a jig to hold them at the right angle?
-Scott
#4 Posted : 15 February 2019 07:50:11
No they were free hand but would recommend making a jig.
Starting Soon!!!!
On the Bench
Milw
#5 Posted : 16 February 2019 18:22:01
Comparing first soldering attempt vs just tying them in an overhand knot slipped over the cascabel.
A problem with soldering will be removing the solder that flowed too far and restoring brass finish (I don’t want to paint).
#6 Posted : 16 February 2019 23:05:07
The only way is a little touch up of brass paint. You wouldn't notice it really.
Starting Soon!!!!
On the Bench
This page was generated in 0.092 seconds.
