snapout Options
snapout
#1 Posted : 20 March 2019 16:36:16
Having electronic problems on the 911. Brake lights do not work and horn does not work. Everything else is fine. How do you troubleshoot hte circuit board? Any suggestions?
shiftf7
#2 Posted : 06 April 2019 12:20:16
I had some trouble too with the circuit board, one of the headlights was not working.
After some experimenting with the wires I discovererd the polarity was switched in the wiring.
I carefully removed the plastic plug from the pins and changed their position. After this everything was working fine.
I guess you could try some experimenting with the polarity also in the wiring, just unplug the brake lights and look if they work when you change polarity.
Good luck!
Daniel
