Running your RB7 at full throttle Options
rb7wu
#1 Posted : 29 January 2017 09:54:27
Hi everyone
I have managed to properly start the RB7's GX21 engine and followed the instruction to set the needle valve. I'm currently running it 3 full turns from close position.
Every time I try to give it a full throttle, the engine gets flooded and shuts down.
Has anyone experience the same issue?
Appreciate some guidance as it is my first gas engine RC.
Thank you.
Eric
amo1872
#2 Posted : 31 January 2017 08:13:53
I had exactly the same problem. I set the HS needle to 2 turns and now I can go full throttle without stalling the engine. I started with 4 turns out and kept leaning it until I got stable full throttle.
rb7wu
#3 Posted : 06 February 2017 22:41:21
Thanks for the tip, it runs at full throttle now.
pwormald
#4 Posted : 20 April 2019 22:55:33
Rank: Amateur level 2
Hi, I finished my build in 2017 and still have this problem of engine stalling at full power. Can't wailt to see if reducing HSN to 2 full turns will give me performance I am sure engine should provide. Still a great model with nothing like it elsewhere.
Having tried reducing HSN to 2 turns I'm afraid it dosen't work for me and I think it was then running too lean. I would appreciate any other help available and hope ther must be a good number of people actually running their car rather than just displaying it. I wonder Tomick if you have any thoughts / suggestions.Crying
pwormald
#5 Posted : 24 April 2019 20:29:25
Furtther to my previous post, I did go through the running in process and I am now using 20% Nitro fuel. Oh I wish to hear it sing!!Huh
This page was generated in 0.222 seconds.
