eck Options
ECK
#1 Posted : 21 May 2019 15:30:17
Red Medal: Red Medal
Started building. Plans are bare minimum, good thing I have built 3 other ships.
First problem is none of the parts have numbers so when fitting the ribs, hopefully I put them in the corset order. Looking at the planking, no measurement is given for where to start the dark wood planking just a picture. This will be very challenging.
#2 Posted : 21 May 2019 15:48:02
If you follow the link provided below and scroll down until you see the "The Build" TAB. Click on that tab and a few lines down you will see a download called HMS Surprise cut sheets. This gives you the part numbers.
Hope this helps.
This page was generated in 0.043 seconds.
