 Rank: Pro  Groups: Registered
Joined: 23/12/2018 Posts: 318 Points: 949 Location: Illinois, USA
Thanks to DeAgostini's Summer sale here in the States, I have just purchased the 12 month Shelby subscription. I've decided that this will be a complete custom build, complete with a Candy paint job.  I won't be posting stage by stage build, but will detail all the custom work. Hope you all enjoy this diary. Mark. Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Joined: 13/02/2011 Posts: 1,988 Points: 6,075 Location: East Sussex uk
Sounds a good build Mark looking forward to seeing your build diary. Trev. Work in progress: Artesania Stage-Coach H.M.S.Victory / H.M.S. Victory Cross Section / De-Agostini Spitfire.
Full Kits: San Francisco. De-Ago Bremen. Sovereign of the seas. Artesania Stage-Coach 2
Hi Mark, looking forward to seeing what you do with this one. Mark
So Here we go. I've painted the trim and valve stem of the front wheels, the steering knuckles, and brake rotors. Using 220 grit sand paper, I scuffed the brake rotors in a circular fashion to mimic rotor wear. The road surfaces of the tires were also scuffed to show wear and tear. I will be posting a complete paint list next and will keep it updated as I move through the build. I'm so excited to get this started. This will be my first custom build in about 40 years as I've just started back modeling this January.  mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Custom 1967 Ford Shelby GT 500 Paint list
Updated 15 August, 2019
Vallerjo Nato Black (71.251) - Wheel Trim, Valve stems Model Masters Flat Gull Gray - Wheel weights Vallerjo Red (71.003) - Disc Brake Calipers Vallerjo Black (71.057) - Steering knuckles, Rocker Arm Covers, Air Cleaner Cover, Vacuum Bodies Vallerjo Aged White (71.132) - Air Filter Vallerjo Gold (71.066) - Carburetors Vallerjo Blue (71.004) - Oil Filler Cap Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
 Rank: Super-Elite        Groups: Registered, Moderator, Administrators, Global Forum Support Joined: 04/06/2011 Posts: 3,166 Points: 9,635 Location: ipswich
Looking forward to seeing what you do with this beastie. It's a great, fun kit with lots of scope for upgrades - particularly in the engine bay.
So today I finished the front wheel assemblies. I painted the carburetors and tops of the rocker arm covers and air cleaner. Also painted the air cleaner element. I used some black sandpaper to simulate the valve cover gaskets. Once assembled I lightly weathered the entire upper end of the engine to look like it has been used. Wrapped these sub-assemblies in bubble wrap and stored away for later. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
