alan j Options
alan j
#1 Posted : 14 September 2019 10:54:02
I am having problems with tank functions,have replaced circuit boards [pack 38]tank functioned but turret did not rotate. have checked all connections which seem tight, tank moved but came to an abrupt stop lights still work back and front but nothing else happens?. any solutions from other tank builders .Please
#2 Posted : 14 September 2019 14:36:36
Hi Alan
Could you double check the connections to the turret motor also check the solder points if it still will not turn try a replacement unit. Its a case of double checking all the connections here plus any solder joints to drive motors ect.
Let me know how you get on.
This page was generated in 0.039 seconds.
