12 Pages «<7891011>»
Soliel Royal by Mark Options
mwstratton
#161 Posted : 19 September 2019 10:05:47
Thanks guys, for looking in and your kind comments.
Under the Bench:
mwstratton
#162 Posted : 19 September 2019 10:07:55
Pack 10 - Stage 105
In this stage I built the Upper galleries on both sides and also fitted the stern panels of all three galleries.
Under the Bench:
mwstratton
#163 Posted : 20 September 2019 13:10:35
Pack 10 - Stage 106
In this stage the stern gallery balconies are assembled. I painted the sides of the hull behind the balcony walls at this stage to make it easier.
Under the Bench:
w1xq
#164 Posted : 22 September 2019 20:55:54
Rank: Amateur level 2
Mark, where is you find Part D on stage 105 step E? It is not on the laser cut fret provided.
Yours is looking great!
Thanks
John
73 de John
W1XQ (ham radio operator)
Amateur Radio Lighthouse Society
Operator aboard Museum Ship USS Stewart and USS Cavalla
Current attempt: Soleil Royal
Prior Builds: Nantucket Lightship, South Goodwin Light vessel, Natchez Packet Paddlewheeler, Souhern Belle Paddlewheel Towboat
w1xq
#165 Posted : 22 September 2019 21:56:58
Senior moment, I found them.
John
73 de John
mwstratton
#166 Posted : 22 September 2019 22:18:13
Thanks
John
Hey John, Part D that you are looking for was included on the fret received with stage 100. I've attached a screen shot of the fret for you. If you threw it out by mistake, customer service will replace it for you. Just call them and request they ship you a spare stage 100. They do not charge for this service.
Are you posting a build diary? Would like to see your progress
stage 100.png (283kb) downloaded 8 time(s).
Under the Bench:
mwstratton
#167 Posted : 22 September 2019 22:21:36
John
LMAO LOL so then disregard my last post.
Under the Bench:
w1xq
#168 Posted : 23 September 2019 01:10:10
Thanks Mark. No, no build diary as I gave up on how to post pics.
73 de John
mwstratton
#169 Posted : 28 September 2019 08:44:12
Pack 10 - Stage 107
In this stage I finished build of the stern gallery balconies. The center plates on the rear balcony walls were fitted then all surfaces were sanded smooth.
All joints and gaps were filled with putty and sanded down. A clear matte sealer was applied to all the raw wood and allowed to dry
Then stern galleries and balconies were painted with French Blue (Vallerjo). the sides of the hull from just below the top row of gun ports up to the gunwales was also painted French Blue.
That's all for this stage.
Under the Bench:
mwstratton
#170 Posted : 28 September 2019 08:49:47
Pack 10 - Stage 108
this stage is quick and simple. The bell and bell arch was built and fitted to the aft edge of the forecastle deck. I drilled holes along the deck edge fot the hand rail. I'm waiting for more 10mm columns from customer service and will finish the hand rail later.
2 2-step ladders were fitted going to each side of the forecastle deck.
Moving on,
Under the Bench:
#171 Posted : 28 September 2019 13:27:50
Looking good Mark, coming along very nicely indeed....Cool Cool
#172 Posted : 28 September 2019 17:22:03
Coming on very nicely Mark.Cool Love
mwstratton
#173 Posted : 04 October 2019 00:57:20
Pack 10 - Stage 109
In stage 109 I fitted the last of the 3x3mm posts to the port and starboard sides of the forecastle deck.
This is also the stage where the gun ports are suppose to be painted. I chose to complete this step BEFORE the final hull planking was applied.
I painted and fitted the 16 round gun ports to the upper decks.
This completes the stage.
Under the Bench:
mwstratton
#174 Posted : 04 October 2019 11:56:14
Pack 10 - Stage 110
I started this stage by building and painting 20 more gun port doors.
2 windows were fitted to the upper ports on the bow bulkhead.
The stern gallery balcony window columns were glued into positions shown.
Then the edges of the transom were built up with 2x5mm wood strips. The strips were painted French blue. The larger columns were then fitted to those strips.
This completes stage 110.
Under the Bench:
#175 Posted : 04 October 2019 12:15:14
Looking good, nicely done.....Cool Cool Cool
#176 Posted : 05 October 2019 00:22:16
BigGrin Looks good to me and nice work MarkDrool Drool Cool
mwstratton
#177 Posted : 08 October 2019 06:25:29
Pack 10 - Stage 111
Drilled the holes in the center of dummy gun ports and fitted port frames to the upper row of ports.
The Windows were installed on the middle and lower stern gallery balconies.
The mizzenmast chainwales were fabricated and fitted to the outside of the bulwarks.
Stage complete
Under the Bench:
mwstratton
#178 Posted : 09 October 2019 01:24:45
Pack 10 - Stage 112
The square window was fitted on the hull just below the mizzen chainwale. The panes of the windows, including the balcony windows, were painted to match the other windows.
The 3 mast collars were fitted around the mast holes in the decks.
The forward chainwales were assembled and fitted along the forecastle bulwarks.
Next I started fitting the decorations to the ship.
The stage is complete.
Under the Bench:
#179 Posted : 09 October 2019 22:40:06
She's really coming together now Mark, looking great.....Cool Cool
nightwisher
#180 Posted : 10 October 2019 18:37:11
Thats a very nice looking ship you have there , love the combination of the blue and gold Love
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
This page was generated in 8.838 seconds.
