R2 D2 Options
WizardJP
#1 Posted : 24 September 2019 12:45:35
Hi,
For those of you that have already started this build.
I'm just about to get started on the X-Wing build and had a question relating to the R2 in the build.
Does his lighting bleed through, does his body/dome need blacking out inside at all? Same question for the engines and lasers too I guess!
Ta
#2 Posted : 24 September 2019 13:13:36
There is some light bleed on the laser cannons, which on the official build diary does suggest painting them black on the inside. With regards to R2-D2, again there is some light bleed so I would suggest painting the inside first to stop this.
#3 Posted : 24 September 2019 14:11:23
Yes there is some light bleed.I painted the inside of R2s head and I did a modification of the laser cannons.I will post about it shortly.It was an easy fix for the cannons
WizardJP
#4 Posted : 24 September 2019 21:10:33
Thanks for the replies, I'll definitely paint the insides of the R2 unit and the cannons, looking forward to seeing your possible mod too!
This page was generated in 0.111 seconds.
