Dennis"s USS Constitution build in Kentucky Options
den75
#1 Posted : 05 October 2019 22:48:31
Hi all,
Finally got my first shipment and getting started on my first pack. Already a question Confused Confused I cut my deck planks to 65mm in length as directed. When I lay them out on the deck they don't look the same as in the pic in the directions. The planks don't come nearly as close to the end of my deck as shown in the directions when I lay them out. Is this a concern. Probably a dumb question, but I don't want to get off on the wrong foot.
den75 attached the following image(s):
Current and First Build: USS Constitution
#2 Posted : 05 October 2019 23:08:42
Hi Den
Take a look at the official build you will see that my planks fall short like yours. Its not a problem as you add more planks as you add the decks all will look uniform.
den75
#3 Posted : 05 October 2019 23:17:47
Thank you Andy. I'll take a look. Just wanted to be sure.
den75
#4 Posted : 06 October 2019 18:53:09
Packs 1 & 2 on the bench from shipment 1
#5 Posted : 06 October 2019 19:41:47
BigGrin Nice start Den and looking goodCool
#6 Posted : 06 October 2019 22:20:38
Hi Dennis,
Off to a good start. Cool Cool Cool
Always ask the question if you are confused as doing it twice can be a pain.Crying Crying
Congrats on your "Blue" medal for starting a diary.BigGrin
nightwisher
#7 Posted : 06 October 2019 23:10:10
Active Service Medal: 500 post active service MedalRed Medal: Red MedalTurquoise Medal: Turquoise Medal for model making know-how contributionBuild-Diary Medal: Build-Diary Medal of Honour
Always nice to see a new ship build diary ,looks like your off to a good start Cool
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#8 Posted : 07 October 2019 00:14:13
Good to see you up and running with this one, look forward to following your progress..... Good luck with your build....Cool Cool
den75
#9 Posted : 07 October 2019 18:56:06
Shipment 1 complete!. Guess I'll just sit around now and stare at it until the next one arrives BigGrin BigGrin . Question, On the forward mast hole, the beam underneath is seen within the hole as you can see by the pic. Does that need to be sanded out so the hole is completely round?
den75
#10 Posted : 25 October 2019 19:42:59
Box 2 arrived. Hoping to get started on it this weekend!BigGrin
#11 Posted : 25 October 2019 20:30:29
Hi Den, in relation to your question regarding the beam across the mast hole. Take a look at stage 5 of the Official Build, the text outlines what you need to do....
https://forum.model-spac...spx?g=posts&t=23303
den75
#12 Posted : 26 October 2019 01:13:53
Thank you. I'll be sure to file it out.
den75
#13 Posted : 31 October 2019 19:12:25
Finally getting started on Pack 2. Maybe it's just me, but sometimes I find the directions confusing since my results don't always match what I see in the pics. For example, it states to draw a line 27mm from the front across the spar deck. In the picture the line is clearly behind the cutout in the front of the deck. When I draw a line on my spar deck 27mm back, it intersects the end of that front cutout as seen in my pictures below. I refer to the official build thread and see that one is the same as mine so that lets me know it's correct.
#14 Posted : 01 November 2019 07:59:32
All looking good and nice work.
#15 Posted : 01 November 2019 09:07:15
Good to see your progress Den, will keep following your work....Cool Cool
If you look at your part and the part shown in the instructions, you will see the slot for the bowsprit in your part is longer than the one shown in the instructions. As long as your line is 27mm from the front then shouldn't be a problem. Also, if you look at the Official build you will see your line position and that shown on the Official build look to be in the same place....Cool Cool
https://forum.model-spac...spx?g=posts&t=23771
den75
#16 Posted : 03 November 2019 02:15:35
Thanks Alan,
I guess the kits have changed along the way. When I looked closer I did notice the difference in the slots.
den75
#17 Posted : 24 November 2019 19:40:42
Got off to a slow start with pack 2, but finally back at it. About halfway through and I have the gun deck on and stained. I went with a dark walnut.
den75
#18 Posted : 24 November 2019 23:29:56
Clamping the spar deck as I go.
den75
#19 Posted : 02 December 2019 14:42:30
Spar Deck Complete
#20 Posted : 02 December 2019 21:55:39
BigGrin All looking good and nice work Den. Drool Cool
This page was generated in 0.193 seconds.
