8 Pages «<34567>»
Goddo's Build Options
z8000783
#81 Posted : 12 September 2019 10:51:53
Not just hard but impossible.
It's looking fine, Chris. You can get it back a little by tapering but personally, I wouldn't worry.
goddo
#82 Posted : 19 September 2019 15:12:25
I am marking out the gun ports for the second row of gun ports.
When it comes to the foremost opening in the bow, if I follow the dimensions given, the port will be across the “twin” bow formers.
Can someone confirm that this is the correct placement, please?
#83 Posted : 19 September 2019 16:02:58
Hi Goddo, can confirm the bow formers are visible through the ports....You won't see them on the finished build.
goddo
#84 Posted : 19 September 2019 16:43:35
Thanks Alan. Full on with cutting more gun ports.BigGrin
z8000783
#85 Posted : 19 September 2019 17:04:50
The covers on those ports will be closed so you just need to dig them out enough for the doors to fit the gap.
goddo
#86 Posted : 19 September 2019 18:42:43
Thanks John. I new they were closed with doors but I was a bit concerned that I had the location a bit out.
goddo
#87 Posted : 03 October 2019 22:30:00
Golf holiday over. Now back to some modelling.
Update below on first two rows of gunport successfully cut.
goddo attached the following image(s):
#88 Posted : 03 October 2019 23:10:15
Nicely done with those gun ports, all looks fine to me.....Cool Cool
#89 Posted : 04 October 2019 05:55:05
Well done all looks good.
Trev
#90 Posted : 04 October 2019 08:05:54
Looking very nice indeed.Love
z8000783
#91 Posted : 04 October 2019 08:28:47
Garth
#92 Posted : 04 October 2019 13:23:29
Hi Chris,
Nice update. The gun ports are coming along nicely.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
goddo
#93 Posted : 09 October 2019 16:21:41
Update on planking and gun ports.
One question, if I may: When it comes to fitting the final top two planks at the bow, would it be acceptable to glue small strips of plank offcuts on the inside to give these two planks something to adhere to?
#94 Posted : 09 October 2019 17:33:35
Hi Goddo, coming along very nicely.
I wouldn't add anything to the bow strips at this stage, it shouldn't be necessary. Take a look at stages 41 and 43 of the Official build, this is when you will start working and finishing off this area, it shows how everything will be held together. Any queries, let me know....
https://forum.model-spac...aspx?g=posts&t=1846
z8000783
#95 Posted : 09 October 2019 19:21:57
Hi Chris
All looking good.
You are correct there is a danger that the top plank may not have much to attach to by the time you get there. The solution is to leave enough space when you lay the plank below. If it is close to the edge, then taper it back a little to provide adequate space for the top plank to sit nicely.
As Alan say, follow the instructions precisely.
goddo
#96 Posted : 09 October 2019 21:22:57
Thank you Garth, Trev, Mark, Alan and John for your compliments and advice.
I will post further updates soon.
nightwisher
#97 Posted : 10 October 2019 18:28:59
Very impressive planking ,very neat and tidy Cool
goddo
#98 Posted : 11 October 2019 00:29:25
Thank you Nightwisher.
goddo
#99 Posted : 22 October 2019 15:37:47
I have almost reached the end of the upper planking but I have one question:
The rearmost upper planks, layers 20, 21 and 22 seem to be starting to the rear of bulkhead #25.
Could someone please confirm that this correct? Looking through the photographs in the magazine, it is not very clear.
Thanks in advance.
goddo
#100 Posted : 22 October 2019 16:24:26
Apologies to everyone.
I have just rewatched the official build video and that confirms that I have got the planking correct.....I think!!
An update with pics will be along shortly.
8 Pages «<34567>»
