 Rank: Pro       Groups: Forum Support Team, Global Forum Support Team, registriert, Forum Support Team Germany, Official Builds, Global Forum Support, Administrator, Administrators Joined: 13/03/2012 Posts: 175 Points: 481 Location: Germany
Hi everybody, I just found a little problem at the right side door of the Samba bus. In step 81-B the support with strap is screwed into the door trim. But in the Bulkhead there are no holes for the door strap with support.I attached two pictures to show up what i mean.  Forum Support Team http://www.model-space.com/de/
 Rank: Pro Groups: Registered
Joined: 25/02/2017 Posts: 152 Points: 452 Location: surrey
Hi Andreas, check part 85 lower front wheel arch, on the inside you will see 2 sets of holes I assume these will be used for the check strap later on in the build. Only my guess though. Andy.
 Rank: Beginner Level 2 Groups: Registered
Joined: 07/08/2014 Posts: 14 Points: 41 Location: london
Surely the part shown with the holes is not the bulkhead?
