VW Samba T1 Official Build Diary - Pack 5 Options
#1 Posted : 27 August 2019 14:22:23
Stage 36
Cab Rear Panel
Parts supplied:
Cab rear panel, Screws BP06.
Retrieve the cabin assembly and unused parts from stage 35.
Line up the pins of the handle with the holes in the bulkhead and press the pins into the holes. Now locate the three holes in the top of the spare wheel housing and note that they correspond with the two pins and hole in the ashtray, which means it will only fit in one way. Next place the ashtray into position and secure it with a BP07 screw from the inside of the housing.
Locate the two posts and two notches on the bulkhead and the two posts and two tabs on the spare wheel housing. Now place the spare wheel housing against the front bulkhead and press the spare wheel housing against the bulkhead aligning the posts of both parts.
#2 Posted : 17 November 2019 15:19:07
Stage 37
Front Floor
Parts supplied:
Front floor, Screws BP06.
Collect together the cab rear panel and the BP06 screws from Stage 36.
Now insert the three posts on the underside of the panel into the corresponding holes in the cab floor and secure the panel with three BP06 screws, checking that the parts are flush as you tighten the screws.
Next align the holes in the front floor with those at the front of the cab floor and press the two parts of the floor together, then secure the parts with five BP06 screws.
#3 Posted : 17 November 2019 15:23:46
Stage 38
Front Floor Carpet
Parts supplied:
Front floor carpet. Accelerator cable (01), Brake cable (02), Gear lever, Handbrake lever, Accelerator pedal, Clutch pedal, Brake pedal, Accelerator plate, Brake plate, Pins, Starter knob, Heating knob, Heating controller, Screw BP06 and BP08.
Place the posts on the underside of the front seat floor carpet into the holes in the front floor and press the carpet into place.
Insert the accelerator pedal into position in the front floor, then turn the assembly over and insert a pin through the aligned holes (smooth end first) and using a pair of pliers press the pin into the hole.
Next insert the brake pedal into the front floor and fix it in place in the same way as the accelerator pedal with a second pin.
Now insert the clutch pedal into the front floor noting that the clutch pedal is not secured from underneath, so check that it is properly positioned.
This page was generated in 0.122 seconds.
