Joined: 08/07/2018 Posts: 23 Points: 69 Location: Canada
Hey peeps, I'm nearing the end (I still can't believe it) and I found some pieces in my spare bag that, after googling and scouring the issues, I can't figure out where they belong. Thanks in advance!
Stage 85 and 99 should help you with at least two of the parts.....
The first triangular part attaches to the left hand mandible at the rear near the main hull. The last part goes on the underside of the hull, the opposite section to the ramp. I’ll try and find exactly the other two parts when I’m back home if you are still stuck. Regards Mark
Markwarren wrote:The first triangular part attaches to the left hand mandible at the rear near the main hull. The last part goes on the underside of the hull, the opposite section to the ramp. I’ll try and find exactly the other two parts when I’m back home if you are still stuck.
Regards Mark These two marked '?' have completely eluded me. Your time is much appreciated (all of you) x_dfo attached the following image(s):
Build stage 24 for another one....
The bottom one on your picture goes on the underside of the hull, here in the picture circled and arrowed in red. It goes into the two holes as shown. Markwarren attached the following image(s):
Markwarren wrote:The bottom one on your picture goes on the underside of the hull, here in the picture circled and arrowed in red. It goes into the two holes as shown. Thanks so much!
The other part is found and fitted here as shown in issue 99. Part 5, fitted in stage 7 in the mag as shown. Mark Markwarren attached the following image(s):
Many thanks to you all, super helpful!
