tank complate but not working Options
Phil112
#1 Posted : 30 January 2020 15:49:51
hi there I have recently built the T-72 tank but it doesn't seem to be working, the light are ok and flashing saying that its made contact with the remote but non of the other functions are work can anyone help me with this.
thank you
#2 Posted : 30 January 2020 16:45:40
thank you
Hi Phil
I`ve not built the T72, but would suggest if not already done that you first check out the instructions in the download after pack 12 instructions (See link below) to check functionality. Check all connections and battery conditions.
https://www.model-space....russian-tank.html#build
Sometimes a pin can be pushed out of place on a connector, so all the above check out ok but things still fail to work.
In the meantime I`m sure somebody will be along to help in more depth who has built this model.
#3 Posted : 30 January 2020 20:54:03
Check out the link below-
https://forum.model-spac...spx?g=posts&t=25307
You can also check the other stickys for info too.
This page was generated in 0.078 seconds.
