R2D2 Problems Options
Mickyc94
#1 Posted : 04 February 2020 22:02:39
Hi. First of all before I go ordering replacement parts I thought I would come to the forum for some advice.
My first build was R2-D2 and I have completed it to the best of my ability. However, i have ran into a couple of problems and not sure what to do.
My first issue is and this only happens sometimes is that when I power on R2D2 he does not always does his self test and only the red light will come on for a few seconds and boot up, he will not move his head like he is suppose to on start up and in the app the head shake wont work but everything else does, like I said this only happens sometimes and takes a few tries to get him to boot properly where his head does move on bootup and the head shake does work. Not sure what the problem could be with that.
My second issue is that only one blue light is showing on his right leg and none on his other leg but both motors are working so again not sure where this problem could lie. I have swapped both cables around in the so LF-M is in RF-M slot and vice versa and still only right leg light shows up so not sure what the issue is here. Dont know if its motor cable issue or faulty led on motor I have no idea.
I was going to be ordering the MCU and the Dome control board again aswell as left leg motor and cables but thought I would come here for some advice.
Other than those problems everything else seems to work completely fine. Batteries fitted are Samsung 30q BUTTON TOP and have been fully charged in supplied charger before fitting. I followed instructions down to the letter upon building it to try and avoid any problems but builds dont seem to work as straight forward as id of hoped.
Anyway, any advice would be appreciated. Thankyou
tschwand
#2 Posted : 04 February 2020 22:18:17
Problem I had was that the batteries were not making good contact in the battery box. After I pulled the batteries and bent the contacts out a bit everything worked. Give that a try. Maybe it will help.
Mickyc94
#3 Posted : 04 February 2020 22:24:13
Yeah I also tried that as few of the contacts were not making contact on the bottoms of the batteries but now they are and its still happening. Im confused as hell and all the batteries seem to be in good working order not sure where to begin other than ordering replacments but dont want to do that just yet without some advice.
#4 Posted : 04 February 2020 23:53:18
It could be a combination of things going on. My first thought is that after you switched the leg cables around it may be an issue with the motor. Check the cables there for contact or even a bent pin. When you start R2 up, the first thing he does is his self check. The first of this part are the leg motors, if they or one is not sending the signal that they are working, he will not continue with the rest of the check, ie dome/ head movement. You said it sometimes works, and other times it doesn’t, try checking the motor cables thoroughly. Also if you have taken the batteries out of the battery box to check them, you will have to start the startup procedure again.
Hope that is a start for you, good luck.
Mickyc94
#5 Posted : 05 February 2020 00:19:03
I have checked the pins on the motor and on the MCU they all look fine to me but the light on the motor doesnt show up on the left leg. Do you think it would just be a good idea to replace the motor and the cable to see what happens rather than the MCU. Strange that the motor actually works though but no LED shows up on it regardless of swapping the cables around.
#6 Posted : 05 February 2020 08:25:56
Yes it might be worth replacing the motor first. Although the motor might work, it maybe electronics in it that is nor working right. The fact that you have swapped the legs over on the MCU and the same leg is not working, doesn’t point to the MCU board.
Cheers
Mickyc94
#7 Posted : 14 February 2020 03:28:19
Cheers
Just thought I would check in. I replaced the left wheel motor and the problem has been resolved and R2D2 is fully operational.
Thread can be closed.
#8 Posted : 14 February 2020 09:07:42
Really pleased you sorted it out. Another R2 in the world.Cool BigGrin
This page was generated in 0.103 seconds.
