Official Standart Build Diary - Pack 8 Options
#1 Posted : 03 February 2020 00:03:49
Imperial Yacht Standart, Pack 8, Stages 68-78.
Stage 68
Stage 68 contents:- Aft Superstructure Fret and a Vent.
Remove part 'A' from the fret and sand the edges smooth. Test fit and glue the part onto the superstructure. Now remove part 'B' from the fret and sand the edges smooth. Test-fit and glue the part to the other end of the superstructure. Next, remove the two part 'C's from the fret and sand the edges smooth. Test-fit and glue the two parts onto the aft end of the superstructure and part 'B'. Separate part 'D' from the fret and glue between parts 'C'.
Retrieve the fret supplied with stage 63 and remove the rudder. Sand the edges smooth then round off the long straight edge. Now cut six 6mm lengths of 1x3mm wooden strip and glue three of them in the positions shown in step 10 of the instructions. Repeat the process to fit the remaining three strips to the other side of the rudder.
Place the rudder onto the keel and mark where the upper end of it overlaps the hull. Cut away the section marked and test-fit in place again.
Stage complete.
Store any unused parts in a labelled bag for future use.
#2 Posted : 14 February 2020 23:41:24
Stage 69
Stage 69 contents:- Propeller Mounts Fret, Gun, Gun Mount and Davits.
Retrieve the parts fret supplied with Stage 53 and remove one of the shoulder pads from it. Prepare the gun and mount in the same way as the others and then glue the parts together.
Remove the two propeller mounts from the fret. Test-fit one of the mounts to the hull, inserting the tab into the corresponding hole at the stern. Now sand the curved edge of the mount to fit flush with the hull. Do this process gradually, sanding the part and then test-fitting again. Repeat until the mount is flush. Sand the long straight edge of the mount into a curve, then sand the projecting end of the mount into a cylinder. Prepare the second mount in the same way.
Glue the propeller mounts into position on the hull. Take a 2 x 5mm wooden strip and smooth the longer edges so it looks like the one shown in step 7 of the instructions. Now cut two lengths of the strip to fit between the keel and the mounts. Make sure the pieces are flush against both parts and then glue into place.
Mark a line across the keel 95mm forward of the aft end, then make another mark on the keel at a distance of 80mm from the point shown in step 10 of the instructions. Now Prepare three 2 x 5 x 250mm wooden strips, glue the first strip to the keel from the mark made at the stern. Then glue the next strip forward of that and the third strip up against that one to the mark made near the bow. Once the glue has dried, chamfer the ends of the strips to
an angle.
Stage complete.
#3 Posted : 17 February 2020 17:23:22
Stage 70
Stage 70 contents:- Wooden Strips, Aft Superstructure Parts Fret and Davit.
Take the 5x5x300mm wooden strips and round one of the corners along the entire length, then paint the strips with a mahogany colour paint. Now paint the unpainted part of the inside of the bulwark black. Once dry, apply a coat of clear varnish.
Glue the two prepared strips along the deck, up against the bulwark and the brass coloured strips. Sand the strips received with Stage 62, and then paint them brass. When the paint has dried, mark lines at 10mm intervals along them. Cut the end of the brass strip on the deck at a 45° angle then repeat on the other side of the deck.
Take one of the strips prepared brass strips and cut one of its ends at a 45° angle. Glue it to the deck along the side of the 5x5x300mm strip. Now prepare a length of the brass-coloured strip to fit in the gap at the end of the mahogany strip; both ends will need to be cut to the correct angle. Glue the piece into place, then cover the joins with black marker, as shown in step 7 of the instructions. Repeat on the other side of the deck.
Cut lengths of the prepared brass strips to cover the aft end of the mahogany strip, and the opening in the bulwark. Cover the relevant points and joins with black marker. Repeat this step on the other side of the deck.
Remove the window frames and doors from the parts fret supplied with this stage. File the edges smooth, removing the joins. Glue the window frames and doors to the side of the aft superstructure.
Stage complete.
#4 Posted : 19 February 2020 22:24:38
Stage 71
Stage 71 contents:- Wooden Strips, Aft Superstructure Details Fret Engine Order Telegraph.
Paint the telegraph with metal primer. When dry, apply black and brass paints as detailed in steps 1 and 2 of the instructions.
Cut eight lengths of 1x3x250mm wooden strips equal to the height of the aft superstructure then glue the strips to the corners of the superstructure. Now glue lengths of 1x3x250mm strips along the bottom edge of the superstructure.
Remove the window frames and doors from the parts fret supplied with this stage and file the edges smooth, removing the joins. Glue the window frames and doors to the side of the aft superstructure then glue the remaining two window frames onto the front of the superstructure.
Retrieve the central superstructure, assembled in Stage 47 and sand all the joins smooth. Glue lengths of 1x3x250mm wooden strip to the corners and then along the bottom edges of the central superstructure. Leave one wall bare as shown in step 11 of the instructions.
Stage complete.
#5 Posted : 21 February 2020 20:58:51
Stage 72
Stage 72 contents:- Aft Superstructure Upper Fret, Windlass and Aft Superstructure Parts Fret.
Apply a coat of metal primer to the windlass, then once this has dried, paint it white. When the white has dried, paint the top of the windlass black.
Remove all of the parts from the aft superstructure upper fret and sand them smooth. Glue one long side panel along the long edge of the large piece, then one side panel to the end. Glue the second long side panel and side panel into place. Leave the assembly to one side until the glue has dried then sand the surface and joins of the assembly smooth.
Cut eight lengths of 1x3x250mm wooden strips equal to the height of the assembly. Glue the strips to the corners. Test-fit the aft superstructure upper on top of the aft superstructure, inserting the ends into the slots. If the bottom of the new assembly isn’t flush, sand it until it is.
Remove the window frames and doors from the parts fret supplied with this stage. File the edges smooth, removing the joins. Glue the window frames and doors to the aft superstructure upper, as shown in step 8 of the instructions.
Retrieve the central superstructure and the parts fret from Stage 38. Carefully separate the parts from the fret and sand smooth. Place the square part up against the bare wall of the superstructure. Mark the point where it intersects the strips at the sides then cut away the parts of the strips just marked. Test-fit the square on the top of the superstructure. It should rest on the tops of the strips and be flush with the top of the part. Trim the strips more if necessary
Stage complete.
This page was generated in 0.141 seconds.
