10 Pages «<8910
Vw Golf 2 GTI Tuned 1/8 Build Options
frah2o
#181 Posted : 09 March 2020 10:31:58
I started the paint work on body.
Before to paint i filled the hole of wiper and i removed the blanked cap for antenna on left fornt fender.
So i started to Sand, primer and check all....after 3 times i reached a good job to finally paint in blue.
Doors and seats are finished with also 3 final coat of clear coat.
Fenders and trunk only painted with 3 blue coat and need final clear coat
Work in progress: Golf GTI 1/8
Completed model: Delta WRC Martini, Delta Test WRC, Mclaren MP4/4
#182 Posted : 09 March 2020 22:25:23
That is a really nice paint job, excellent work.Love Love Drool
frah2o
#183 Posted : 17 March 2020 12:28:44
I'm continuing with paintwork and I'm arrived to bodyshell.
I removed all balck trim and stripes, i coat with primer. I check all defects and and i give another primer coat.
I finallu paint the bodyshell with 4 coat of blue.
I removed the iniejcton point from bonnet and i paint it with same ways of bodyshell
Before to coat all with clear, I polished all with silicone remover, than i coated with 3 layer of clear
I masked all bosyshell and i painted the roof trim. I meade the trim for doors, windows and trunk with rubber tape.
frah2o
#184 Posted : 17 March 2020 16:31:12
2/2
I flocked the pillars like on my 1:1 GTI
I worked on carbon door card. I add a rounf frame on manual glass knob, I add a yellow stripe to close the door and a metal wire to open the door.....and finally I adde a Metal knob to regulate the mirror.
I also fitted the last rubber trim on trunk
And some pics whith bodyshell and fenders mounted
#185 Posted : 17 March 2020 20:55:11
That really is looking great.
I love that colour!Love
frah2o
#186 Posted : 23 March 2020 13:18:16
Many thanks Roy.
1/2
I quite completed the hatch
i remade the rubber trim of rear glass, and also i modified the rear license plate light bar as "Cult Society" light bar like on my 1:1 mk3
I also added some PE bolts anfd paint the license lights.
I fitted also the 5 point seat belts using the rear struts bar
I worked on airride tank system. I machined an alu tnak, i added the inlet and outlet air connection. I assed the black rubber stripes and i fixxed with yellow belts
Like one my GTI 1:1 i made the bracket for CDA of BMC.
I also fitted the oil engine radiator carbon duct.
When the front girll will be fitted i added the hose to duct the air to airbox and radiatore
Some details (some bolts and decal set taht it's coming) and engine compartment is completed.
frah2o
#187 Posted : 23 March 2020 14:19:30
2/2
Some overall pics and some test with other rims
frah2o
#188 Posted : 25 March 2020 22:03:27
I placed the viper cover adding a battery cut off swhitch.
I completed the roof trim and finally i placed hatch, bonnet and doors.
Next week i hope will arrive the decal set to fianally fit chassis with bodyshell
bfam4t6
#189 Posted : 26 March 2020 02:10:44
Rank: Amateur level 2
Paintwork looks great!
Currently Building:
-Porsche 2.7 RS
-Jaguar E-Type
-Ford GT40
Currently Collecting
-Ferrari F40
-Ferrari 250 GTO
frah2o
#190 Posted : 26 March 2020 11:59:05
Thanks....i tries to do my best with this big model
I’m finally arrived to marriage chassis and bodyshell
Before make this, i stripped out the chrome from rear badge and I repainted them in semi matt black
I adjusted the height of door hinges to match all panel lines
I worked on tail light to match the combo color lenses of the Golf Special edition. I also flocked the inside of tail lights
I also give some detail to front radiator bar: I drilled the blankes holes and repainted in titanium gold the bonnet latch. I’ll add in the future some final PE and bolts.
bfam4t6
#191 Posted : 27 March 2020 22:39:07
Nice update, great work as always!
Currently Building:
-Porsche 2.7 RS
-Jaguar E-Type
-Ford GT40
-Ferrari F40
-Ferrari 250 GTO
frah2o
#192 Posted : 28 March 2020 14:11:38
Many thanks
Incompleted the inlet air system for oil cooler radiator duct. The yellow hose start from the removesd high beam light and link to radiator duct.
To fix the metal mesh i machined the lenses of high beam light. I also add the bixenon bulb on black headlight.
To reach a total dark look I black painted the mesh....i also added the PE screw for beam regulation.
I did some detail work adding some head bolts on Airbox bracker and radiator bracket, at the end i completed the last air hose inlet for airbox.
andali15
#193 Posted : 28 March 2020 14:20:35
Very impressed with your build. So much detail has been put in, you should be proud of all you’ve done. Andy.
frah2o
#194 Posted : 30 March 2020 07:44:37
Thanks very much Andy! Blushing
I was arrived to the end of this long project that began almost 4 years ago with various stops and start.
During the week should arrive all decals (including license plate and VIN) and then I'll do the final outdoor photo set
I worked on his home case a nd I reuse some spares parts fixxed on the wall...like on my 1:1 garage of my mk3.
#195 Posted : 30 March 2020 09:31:01
Very impressive, great result.Love Love Drool
#196 Posted : 30 March 2020 11:16:47
Amazing work as always. A great display space there too.BigGrin
Andreas
#197 Posted : 30 March 2020 11:25:46
Build-Diary Medal: Build-Diary Medal of HonourPublisher Medal: Article published MedalActive Service Medal: 500 post active service MedalRed Medal: Red MedalTurquoise Medal: Turquoise Medal for model making know-how contributionOutstanding Build: An award for an outstanding build
Amazing Roy !
love it!absolutely realistic. great Job!BigGrin ThumpUp
frah2o
#198 Posted : 02 April 2020 12:09:02
Thanks to everybody Blushing
I started the decal work to add on my model.
10 Pages «<8910
This page was generated in 0.237 seconds.
