Testing the X-Wing functions Options
#1 Posted : 29 April 2020 00:43:22
Hi All,
It has come to my attention that a few of you have run up against the problems associated with testing all the functions of the X-wing.
The directions got a bit ahead of themselves, and have you test the functions BEFORE you have all the required parts in hand. There is a cable provided in issue 74 that is ABSOLUTELY REQUIRED in order for all functions to work. If you try testing prior to issue 74, IT WILL NOT WORK! This does NOT MEAN that you have anything defective! Just wait until you’ve received issue 74, and all will work.
(As a reminder, any attempts to “Hotwire” your build that result in a damaged motherboard ARE NOT COVERED by the DeAgostini warranty)
Albert Eisenstein
This page was generated in 0.070 seconds.
