VW Beetle Custom build - Pack 9 Options
#1 Posted : 06 June 2020 13:55:24
STAGE 67
These parts are for the inner rear body panel. Assembly is very straightforward and the panel is fixed to the interior of the rear body.
STAGE 68
This pack contains the other interior rear trim panel.
This is re-trimmed to match the rest of the interior if you have modified it.
Fitting the inner panel is done in the same way as the opposite side of the car.
STAGE 69
This pack contains the front body section of the car. No work is needed at this point.
STAGE 70
This pack contains the 1st front body side panel.
If you are applying decals or painting these panels it can now be done.
When the decals/paint is fully dry, the panel is screwed to the front body section.
Make sure the screws are fully tight.
STAGE 71
This pack contains the 2nd front body side panel.
It should be fitted to the front body in the same way as the previous part.
STAGE 72
This pack contains the windscreen for the car.
It should put to one side for now.
STAGE 73
This pack contains the frame for the windscreen. These parts can now be fitted to the main body. Assembly of these parts is simple but take care to ensure the screen is located properly in the metal screen frame before fitting the trim part.
STAGE 74
The interior mirror and sun visors are included here and these can be fitted to the top of the windscreen frame.
#2 Posted : 06 June 2020 16:39:39
Nice work Roy, that's going to look very colourful when finished.Love
#3 Posted : 07 June 2020 08:57:45
Beautifully done Roy, she's certainly developing her very distinctive look.... Love it.....Love Love
