Joe Bergman Pack 4 Custom Build Stages 10 thru 13 Options
bojazz
#1 Posted : 12 July 2020 21:57:48
We are back with pack 4.
The only parts that are being assembled, are the modified car seat section.
In the past pack we used a Tamiya Dark Brown Panel Liner to get a desired effect. This stage (10,11,12) of the build will show you that desired effect.
The remain stage 13 of building the left door will not be modified (weathered) until the body is assembled
Here are the seat results......... See you on the next Build and Thank you for the support.
bojazz attached the following image(s):
This page was generated in 0.078 seconds.
