Glue for McLaren 4/23 build Options
Lukas2020
#1 Posted : 23 July 2020 19:08:54
Hey
I am looking for help about glue. I am going to build Deagostini McLaren 4/23. The instruction says there will be three glue type needed.
"You will require three types of glue for the assembly of this model, one suited to the bonding of ABS plastic to ABS plastic, another being Superglue (cyanoacrilate) for bonding metal to plastic, (a gel or 'thick' type superglue is better controlled), and finally a General Purpose glue (epoxy)."
I already know Tamiya so I found they have this glue
TAMIYIA cement (for ABS resin) so I bought it is it ok?
[https://tinyurl.com/y255zxd5](https://tinyurl.com/y255zxd5?fbclid=IwAR1ub2B5iSAC-_JjNytSTaKtLzgS6OVP7ah0kYSOG52Sg95dNbHP_H83n_0)
What about epoxy I dont know I only found they are made of two parts and has to be mixed?
Superglue thick or gel would be better for models? Tamiya CA Cement quick type is ok?
What do you use to apply glue?
This page was generated in 0.521 seconds.
