2 Pages <12
GWH F-15C MSIP II by DaDokta Options
DaDokta
#21 Posted : 13 May 2020 09:23:24
After priming i tried some preshading with blue and white colours.
DaDokta attached the following image(s):
Greetings,
Walter
Present builds:
GWH F-15C
On the shelf:
Completed builds:
DaDokta
#22 Posted : 13 May 2020 09:25:51
Only to then almost kill it off with aluminium and some "pale burnt metal".
The airbrush still is not my best friend! :))
Greetings,
Walter
Present builds:
GWH F-15C
On the shelf:
Completed builds:
DaDokta
#23 Posted : 13 May 2020 09:39:07
In the end i wasn`t happy with the look - it was too bright.
So i started over with a "steel" base coat - as this was a little bit darker.
I then applied some self-made filters to achieve a "gold-ish" and towards the rear end a more blue-ish tinge.
I think now it matches the look on the real thing somewhat better.
Greetings,
Walter
Present builds:
GWH F-15C
On the shelf:
Completed builds:
bfam4t6
#24 Posted : 14 May 2020 17:41:57
Rank: Semi-Pro Level 2
Looks like you're starting to get the hang of that airbrush. I think the exhausts look great!
Currently Building:
-Porsche 2.7 RS
-Jaguar E-Type
-Ford GT40
Currently Collecting
-Ferrari F40
-Ferrari 250 GTO
DaDokta
#25 Posted : 15 May 2020 10:00:36
Thank you!
The exhausts are now done.
Greetings,
Walter
Present builds:
GWH F-15C
On the shelf:
Completed builds:
DaDokta
#26 Posted : 08 June 2020 13:42:55
Guys - if anyone is looking in here - i need your help!
As you can see on the attached pic of the decal sheet - a lot of decals exist in two different shades of Grey.
So which decals do i use - as they have the same number????
Is there a right or wrong or is up to my taste?
Thanks for your help!
Greetings,
Walter
Present builds:
GWH F-15C
On the shelf:
Completed builds:
#27 Posted : 08 June 2020 21:34:14
Hello Walter,
I am guessing that you have two different marking/colour schemes provided with this kit and that one of them is a 'low-viz' all over grey scheme, and that the other is a multi-coloured camouflage type?
If so, then the slightly paler set of decal markings, which would also include all of the various 'stencils', would normally be applied to the 'low-viz' grey scheme (in order to maintain the overall 'low-viz' aspect) and the slightly darker set would be applied in exactly the same places on the camouflaged scheme, if that is the version you wish to build. You shouldn't mix the two colours of markings together on the same model, you have to choose one or the other depending on which version of the kit you are building? Hope that makes sense?
Do you have a photo of the colour/markings page in the instruction sheet that you could post for me to check and for clarification?
Kev.
DaDokta
#28 Posted : 09 June 2020 06:26:29
Thanks Kev! That would make sense - but i`m afraid both versions, that can be built with this kit, are camouflage type paintings.
I´ll provide pics tomorrow as i`m not at home today.
I guess it will come down to the builder`s preferences - and i myself tend towards the darker ones.
Greetings,
Walter
Present builds:
GWH F-15C
On the shelf:
Completed builds:
#29 Posted : 09 June 2020 10:03:32
Walter
Hello - hope all is well with you.
Not sure if the link below may help.
Its a decal sheet similar to your kits with high and low vis markings.
It mentions ghost grey colour used high vis Markings and the later “mod eagle” Used low vis.
https://www.cybermodeler...ges/caracal_48091_p.jpg
Grey and greyish blue i think are the colours used in your kit so i personally would use the low vis markings, which looking at a few pictures seem to be the style used on the greyish blue.
There are various pictures here that may help
https://commons.wikimedi...r_St_Louis_IAP_2008.jpg
https://www.markstyling.com/f15c1.htm. Pictures 6 7 and 8 here.
https://www.google.co.uk...08#imgrc=xW4fuATT39YA0M
DaDokta
#30 Posted : 09 June 2020 12:09:01
Thanks Tony - this was of great help.
So the lighter grey-version seems to be the way to go.
Greetings,
Walter
Present builds:
GWH F-15C
On the shelf:
Completed builds:
DaDokta
#31 Posted : 17 June 2020 10:21:03
A small update:
The main parts are all glued and all parts primed.
This is what she looks like after preshading - still a lot of problems with my airbrush!!
Greetings,
Walter
Present builds:
GWH F-15C
On the shelf:
Completed builds:
DaDokta
#32 Posted : 29 June 2020 13:56:26
This is what she Looks like after my first attempts of bleaching:
Greetings,
Walter
Present builds:
GWH F-15C
On the shelf:
Completed builds:
#33 Posted : 29 June 2020 16:42:12
Looks good to me ThumpUp
Regards Gray
#34 Posted : 30 June 2020 07:55:16
I agree with Gray, think this is coming along very nicely indeed. Looking good....Cool Cool Cool
#35 Posted : 30 June 2020 08:21:32
Nice work, looking very good.Love ThumpUp
DaDokta
#36 Posted : 20 July 2020 09:42:03
Thanks guys!
I finally found some time to add the second colour of the scheme including bleeching.
Greetings,
Walter
Present builds:
GWH F-15C
On the shelf:
Completed builds:
#37 Posted : 20 July 2020 12:22:02
Awesome work on the paint job Walter. Drool
On the bench
DaDokta
#38 Posted : 31 July 2020 12:08:15
Painted the metallic areas and some smaller details.
Greetings,
Walter
Present builds:
GWH F-15C
On the shelf:
Completed builds:
#39 Posted : 31 July 2020 13:10:36
BigGrin Hi Walter
Good to see your skill with wood has transferred over just as well with plastic ThumpUp
Regards Gray
#40 Posted : 31 July 2020 19:44:27
Very nice work Walter.Love
2 Pages <12
This page was generated in 0.555 seconds.
