Thanks to everyone for their kind comments.
Time to fit the body panels over the chassis. I'll complete the body but will display this one with a lot of the innards showing  Malc. RM1 attached the following image(s):
Got the bodywork pretty much sorted. Exhaust system painted and located. The body panels have required very little work to get ready for finishing. Malc.RM1 attached the following image(s):
 Rank: Pro  Groups: Registered
Joined: 25/12/2019 Posts: 117 Points: 356 Location: USA
Wow, this is a real treat. Definitely something to aspire to. “Details make perfection, and perfection is not a detail.” -Leonardo Da Vinci
Currently Building: -Porsche 2.7 RS -Jaguar E-Type -Ford GT40
Currently Collecting -Ferrari F40 -Ferrari 250 GTO -Lamborghini Miura
An excellent example of how to assemble a model, truly stunning Malc..... Regards Alan
Just stunning what you have achieved so far. Mark
 Rank: Super-Elite        Groups: Registered, Moderator, Administrators, Global Forum Support Joined: 04/06/2011 Posts: 3,098 Points: 9,461 Location: ipswich
Absolutely brilliant. It's going to be a centrepiece.
Joined: 29/03/2011 Posts: 1,023 Points: 3,075 Location: Glenvista JHB
Hi Malc, This is getting better and better!!! Fantastic update. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Thanks to everyone for the kind comments !! Malc.
 Rank: Super-Elite      Groups: Moderator, Tech Support, Technical Support, Registered, Forum Support Team, Forum Support USA, Global Forum Support, Global Forum Support Team Joined: 17/12/2013 Posts: 3,799 Points: 11,429 Location: NY, USA
Syperb.Those resin parts are really nice.How as the fit.I know sometimes the MFH body panels give people a lot of trouble with the fit.
darbyvet wrote:Syperb.Those resin parts are really nice.How as the fit.I know sometimes the MFH body panels give people a lot of trouble with the fit.
Thanks Carl. The panels have been pretty good so far. A small amount of cleaning and the fit seems to work. The die cast undertray will need a bit of adjustment to get the rear body section positioned over the fuel tank.
Malc.
It takes a great deal of effort for any model to get the 'wow' factor and this is definitely one of those models..... In other words - 'WOW!!!'... Regards Alan
Rank: Administration  Groups: Administrator, Administrators Joined: 24/08/2009 Posts: 1,386 Points: 4,276 Location: Nevada, US
RM1 wrote:admin wrote:This is looking beautiful! I drooled on the pics of your chassis, (STOP THINKING THAT!!!) then somehow found myself working on my MFH Bugatti T-35..... Thanks Mark, please stop drooling over my chassis... . That Bugatti is on my wish list. I'd like to do the first Monaco winner. Malc. Hey, nothing in there will rust! And, I told you to stop thinking that! Mark Adams
Next "Mini-project" the nose grill. All from PE and the difficult part is getting started with everything "square" despite the curves and angles. I made a simple jig to hold two crosspieces and started in the centre. Malc.RM1 attached the following image(s):
A central cast piece keys into the PE parts and provides a good datum to work with. With all crosspieces in place the fit into the nose can be checked. I'm using a tiny drop of CA to bond the parts.RM1 attached the following image(s):
My thought on that little challenging bit had been to use Legos to creat the square. I’ll be using solder though. I’ve found a great 70c low melt solder that I get from your side. I mostly use it for the white metal it I’m starting to use it on the stainless as well. I rather like your method better. It would be a lot easier to square that bit of WM first. Thanks! Mark Mark Adams
admin wrote:My thought on that little challenging bit had been to use Legos to creat the square. I’ll be using solder though. I’ve found a great 70c low melt solder that I get from your side. I mostly use it for the white metal it I’m starting to use it on the stainless as well.
Thanks!
Mark Hi Mark, I've seen some of the guys using a low temp' solder on WM. It's something I've been pondering on for a while. Would you be able to let me have the detail of what you use ( you say it's from this part of the world? ) plus a recommendation on a suitable temp' controlled Iron. Many thanks for commenting on the build. Malc.
That nose grille is mind boggling. It's going to be amazing when it's all assembled. Fantastic work.
Joined: 25/11/2018 Posts: 815 Points: 2,462 Location: Southeast UK
Beautiful work Malc, very precise detailing with that grille.....  ... Looking forward to seeing more of your work.... Regards Alan
Just an amazing kit to construct. The detail is breathtaking, but all would be lost if not in the hands of a talented builder. Amazing work. Mark
