16 Pages «<141516
Goddo's Build Options
goddo
#301 Posted : 30 January 2021 14:11:14
I have used a hair dryer to blow out the gun port openings in the past and I think a soft, long haired paint brush is about the only answer I can think of to dust off all the deck details etc.
goddo
#302 Posted : 11 February 2021 17:54:15
I have a predicament in the bow section, regarding belfry/gratings/mast spacing.
From the attached photo, you can see that if I space the gratings as per instructions, the gap to the legs of the belfry is only approx 2mm. If I move the belfry back so that the rear legs sit on the opening trimmer, I can achieve 5mm. Has anyone else come across this problem or have I got something set out incorrectly?
goddo attached the following image(s):
goddo
#303 Posted : 22 February 2021 18:41:25
I've been jogging along in a fairly random sort of way but I finally managed to get the cannons and carronades fitted.
Just got to make some more rope coils to finish things off.
Next stage is the chain wales which, I must admit, I am not looking forward to. One thought I did have was to replace the copper wire "loops" with black thread or small link chains. What do you think?
goddo
#304 Posted : 22 February 2021 18:51:30
A bit out of sequence.
Another update on the bow decoration.
nightwisher
#305 Posted : 22 February 2021 22:23:00
Active Service Medal: 500 post active service MedalRed Medal: Red MedalTurquoise Medal: Turquoise Medal for model making know-how contributionBuild-Diary Medal: Build-Diary Medal of Honour
Great stuff , love watching this build I might pinch a few of your ideas hope you don't mind.
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
goddo
#306 Posted : 23 February 2021 00:32:10
Thanks for the praise, nightwisher.
Be my guest with any ideas you fancy using.
I only get most of these things from other members on here. That's what these forums are for, to help fellow modellers enjoy their build even more.
#307 Posted : 24 February 2021 00:13:52
This is really turning out to be a stunning build... Keep it going and you'll end up with a display build you can be really proud of.....Love Love Love .. Love it.....
goddo
#308 Posted : 24 February 2021 18:19:52
I mentioned previously that I didn't really like the brass wire "loops" provided in the kit to go below the chainwales.
As I haven't been able to locate a sensibly sized linked chain to try, I have used black thread as a test.
Any comments appreciated before I move on to the other chainwales.
#309 Posted : 25 February 2021 12:59:48
Hi Goddo, BigGrin
Looking good.Cool Cool Cool
Ref: Your question about the links under the chainwales, I`ve sourced an image of the real thing (attached below) and its just two links so very unlikely you will find anything like it elsewhere. For authenticity the brass wire loops provided are closest, but at the end of the day its your build so go with what you are most comfortable with. (Yes, I`m sitting on the fence with this one LOL )
goddo
#310 Posted : 25 February 2021 14:03:11
Thanks for taking a look at my model Derek and showing me the photo of the real thing.
I'll give it some thought over the next day or so.
Roeland
#311 Posted : 25 February 2021 16:44:27
I found the brass wire too difficult to work with and used copper instead. It was a lot easier to bend without breakage.
#312 Posted : 25 February 2021 17:02:48
Hi Chris,
This is turning out to be a stunning build, thanks for showing us.
Trev
Work in progress: Artesania Stage-Coach H.M.S.Victory / H.M.S. Victory Cross Section / De-Agostini Spitfire.
Full Kits: San Francisco. De-Ago Bremen. Sovereign of the seas. Artesania Stage-Coach 2
#313 Posted : 26 February 2021 01:09:10
Hi Chris, in relation to the brass link question. You may like to consider purchasing soft brass wire from CMB. The soft brass wire is much easier to work with and is something I've used a few times on my builds... Cool Cool
16 Pages «<141516
This page was generated in 0.171 seconds.
