X-wing stand Options
fossie67
#1 Posted : 01 April 2021 08:52:41
Been looking through the builds and i like Wabies stand . Anyone got a link for this stand in the UK or anyother ideas .
Silent_Running
#2 Posted : 01 April 2021 09:54:44
Hi fossie,
I think the quickest way to get this stand is to send Wabie a PM and ask him where he got it. He will probably even send you the link to it if you ask him.
Kind regards
Glenn
Wabie
#3 Posted : 01 April 2021 10:29:22
Hi Fossie,
Here is the Link to the Stand from EBay
https://www.ebay.de/itm/...=p2349624.m46890.l49286
You need a M8 Bolt to fix the XWing
Greetings Stefan
MfG Stefan
Silent_Running
#4 Posted : 01 April 2021 10:42:24
Hi Stefan,
Very much appreciated thank youBigGrin
Kind regards
Glenn
bmwiggins
#5 Posted : 01 April 2021 13:38:59
Wabie wrote:
Hi Fossie,
Greetings Stefan
Hi Stefan,
Your build also mentioned you had 3D printed an adaptor for it to fit.
Is that something you would consider doing a small production run of?
Built - R2D2, Thunderbird 2, X-Wing / Building ( Ha!) - Millenium Falcon
fossie67
#6 Posted : 01 April 2021 14:28:49
Many thanks for pm Wabies
fossie67
#7 Posted : 02 April 2021 19:41:47
Cracked it . Had a rummage in the shed and i knew i had an M8 thread . In the shed i found a floor lamp . It had a heavy base and 4piece tube upright . Anyway was able to cut down one of the tubes and run the M8 bar through the centre . Bingo nice little table top stand .
