2 Pages <12
3D Printed Highly Detailed Aftermarket Upgrades Options
TonyRR
#21 Posted : 11 March 2021 20:04:53
Another great part that you can improve is the ramp hidraulic lifters. I've redesigned them to make this part screen accurate as much as possible.
You can get a set in this link to my shop!!
308 Bits Shapeways shop DeAgo Falcon Ramp Lifter Set
TonyRR
www.shapeways.com/shops/308Bits
Higly detailed 3D printed upgrades for scifi kits
TonyRR
#22 Posted : 15 March 2021 20:19:14
The DeAgo hold is also a zone to be heavily upgraded. I've designed some pillars, screen accurate at the max.
You can see the attached shot.
You can buy it here
308 Bits Shapeways shop Deago Hall Pillars
TonyRR
TonyRR
#23 Posted : 19 March 2021 20:50:46
I've modelled a lot of upgrades for the DeAgo Falcon during these years.
In this render you can see some of the hold upgrades available in my 308 Bits Shapeways shop.
Enjoy!!
You can buy all of them in my 308 Bits Shapeways shop.
308 Bits Shapeways shop DeAgo upgrades
TonyRR
#24 Posted : 19 March 2021 22:35:13
Drool Drool Drool Thes are just amazing upgrades! If i ever get the remaining issues im going to be spending some serious coinage here Love
Gray
TonyRR
#25 Posted : 19 March 2021 22:53:16
Gray
Many thanks!!! If you have any questions please let me know.
TonyRR
TonyRR
#26 Posted : 26 March 2021 17:25:28
What about a new and accurate turret gun well? I've designed a very screen accurate turet gun well with all the details and with the right seat. And it has pre drilled holes for 0.25 mm fiber optics.
And it can be installed with no hassles on the stock hull, because it has the stock part dimensions. For ease of paint it's sliced in two halves.
You can get it in my 308 Bits Shapeways shop, of course, in this link:
308 Bits Shapeways shop DeAgo Turret Well Stock
TonyRR
TonyRR
#27 Posted : 06 April 2021 19:32:49
A set of 3D printed hold pits grille it's a great addition to the DeAgo Falcon.
I've modelled a set totally screen accurate, that's available in one piece or in three separated halves.
Of course it's fully compatible with my hold grille.
You can get it at my 308 Bits Shapeways shop on the link below.
308 Bits Shapeways shop DeAgo Falcon Hall Pits Grille
TonyRR
TonyRR
#28 Posted : 11 April 2021 17:44:24
I recommend to upgrade the DeAgo Hall Nav console. The stock one is innacurated and doesn't have the right size.
My Hall Nav Console has more than 80 pre drilled holes for 0.25 mm fiber optics too, so it's a win win.
You can get it here!
308 Bits Shapeways shop DeAgo Hall Nav Console
TonyRR
TonyRR
#29 Posted : 12 April 2021 19:41:25
What about a set of external warning lights? This is a missing feature on the DeAgo!!!
I've designed a set of external DeAgo housing warning lights, that you can light with small led.
You can get them in my shop, as usual.
308 Bits Shapeways shop DeAgo External Lights
TonyRR
TonyRR
#30 Posted : 18 April 2021 20:34:55
The stock engine vents can be upgraded with a fan under the grilles.
I've designed a set of fans to be installed under my engine vents grilles.
You can get them in my 308 Bits Shapeways shop!!
308 Bits Shapeways shop DeAgo Engine Vents Fans
TonyRR
TonyRR
#31 Posted : 26 April 2021 19:14:40
For the very advanced modellers I've designed a full set of screen accurate ramp walls. The problem is that they don't work with the stock electric motor and ramp elevation system. But you can adapt them.
You can get the ramp panels and the hull ramp interlock in my 308 Bits Shapeways shop.
308 Bits Shapeways shop Millennium Falcon Deago Ramp Panels
TonyRR
TonyRR
#32 Posted : 02 May 2021 20:25:03
The engines of the DeAgo Falcon also can be improved heavily. One detail are the engine louver arms, that on the stock DeAgo aren't very well designed. My upgrade for this part is totally screen acurate, and fits perfectly in place. And my plates overhang a bit, like on the studio model.
You can get them in my 308 Bits Shapeways shop under the Falcon DeAgo tab.
308 Bits Shapeways shop DeAgo Falcon Engine Louver Arms with Plates.
TonyRR
2 Pages <12
This page was generated in 0.138 seconds.
