4 Pages «<234
JOHN-GT40 BUILD DIARY Options
JOHN-GT40
#61 Posted : 06 May 2021 14:53:00
Rank: Semi-Pro Level 2
2nd coat of TAMIYA ZF-16 flat aluminium has been applied
More updates will follow soon
Thanks
JOHN RICHARD POULTER
JOHN-GT40
#62 Posted : 06 May 2021 16:04:26
Radiator silicone hoses painted in TAMIYA xf-8 flat blue
Fixing screw painted in TAMIYA xf-16 flat aluminum
Oil cooler hose fitting painted in TAMIYA xf-16 flat aluminum
More decals have been ordered
Future updates will be posted soon
Thanks
NOTE THIS IS CORRECT WAY TO INSTALL BRAKE COOLING DUCTS INTAKES
AND NOT AS ON THE PDF INSTRUCTIONS
JOHN-GT40
#63 Posted : 07 May 2021 16:07:20
Interior tub now fitted and secured onto the chassis
All mounting points are painted in humbrol satin black
All securing holes at front and rear have been filled with model filler and sanded and painted in either humbrol enamel black or TAMIYA flat aluminium to give a better quality smooth finish
Outer leading edge of engine compartment was filled with model filler to chassis to give far better quality finish and sanded smooth and painted in TAMIYA flat aluminium
more updates will be posted soon
Thanks
#64 Posted : 07 May 2021 16:29:56
You're getting on well with this one John.
I really need to do a bit more on mine.LOL
JOHN-GT40
#65 Posted : 09 May 2021 17:36:31
Interior tub now attached to chassis now weighs in at 1.716kg
More posts will be posted soon
Thanks
JOHN-GT40
#66 Posted : 09 May 2021 18:18:54
Transmission
All exterior screw holes filled with humbrol model filler
Transmission painted all over in TAMIYA flat aluminum
Then additional colours were applied
Rear transmission case painted in humbrol satin black
Transmission top case painted in gun metal grey
Transmission rod base painted in flat aluminium
Transmission rod ball joint in gold leaf
Transmission rod bush in gold leaf
These colours were obtained from
Fein design 1:8 scale Ford GT40 (1969) scale engine
Thanks
JOHN-GT40
#67 Posted : 10 May 2021 10:23:47
New decal artwork approved
3 x sabelt yellow logos for spare wheel harnesses
Ignition warning lights in blue, yellow, green, red to go around Rev counter
Engine chassis plate to go on left side close to fuel pump system
427 cubic inch high performance air filter decal
Thanks
JOHN-GT40
#68 Posted : 10 May 2021 18:03:57
Front end is all now fully built
Points to note at this stage
When building up suspension do this with the wheel removed it is so much easier
Fitting tyres submerse in boiling water for 5 minutes and they become far more easier to install and fit
Just a update the 9mm non split convoluted conduit I used for front brake cooling tube fits a lot better than the supplied part
Radiator mounting on the right hand side opposite to oil cooler and has been filled in with Humbrol model filler, sanded smooth and painted in Tamiya xf-16 flat aluminium
Outside area of brake cooling intake has been painted in Humbrol satin black enamel to give the all black effect all over but the inside remains in flat aluminium finish
I purchased additional parts to fit for spare wheel , 1 x chrome screw and 3 pointed star wheel spinner for the spare wheel
Now looking forward to my next issue number 16
Additional decals have been ordered and awaiting on when they can be collected
Many thanks
JOHN-GT40
#69 Posted : 10 May 2021 18:07:56
Up to issue 15 it now weighs in at 2.667kg
Thanks
JOHN-GT40
#70 Posted : 14 May 2021 12:03:06
I have one additional set of decals consisting of
3 x sabelt logo decal for spare wheel straps
4 x dash warning light decal to go around the Rev counter
1 x engine chassis plate decal to go next to fuel pump system on bulk head
These are free of charge and will be sent via Royal Mail special delivery service and the first forum that is very seriously interested
Please p.m. your data details consisting of name , address , post code
This is for the first individual only as I have only one additional set
Thanks
JOHN-GT40
#71 Posted : 14 May 2021 14:00:03
Decals have turned up and decals have been installed and they look amazing
I do have one additional set available
P.M. if you are interested these are free of charge to the first seriously interested forum member and will be sent via Royal Mail special delivery
So P.M. your data name / address / postcode
Remember first come first served , I only have one additional set
these are free of charge to first individual that wants them
Thanks
SO SORRY THESE ARE NOW GONE TO A FELLOW FORUM MEMBER
MANY THANKS FOR ALL THE INTEREST
#72 Posted : 15 May 2021 10:57:13
Another nice update John. Keep it all coming.BigGrin
JOHN-GT40
#73 Posted : 09 June 2021 17:19:39
ADDITIONAL FUEL HOSE ATTACHED TO BOTTOM OF FUEL PUMP FROM ADDITIONAL PARTS I HAD ORDERED FROM MODEL SPACE UK
TRANS AXLE ALL PAINTED & LOOKING GOOD
GEARKNOB PAINTED IN TAMIYA WALNUT BROWN THEN CLEAR COAT GLOSS VARNISH APPLIED TO FINISH
JOHN-GT40
#74 Posted : 13 June 2021 03:48:23
Where I get all my research from:-
Fein designs = 1:8 scale ford gt40 engine
29 designs.de = 1:8 ford gt40 upgrade parts
Shapeways.com = 1:8 scale 3D printed model parts
Amalgam diecast models = ford gt40 in 1:8 scale
Shelby American black limited edition gt40
Superformance for gulf edition gt40
Hope this helps you all out
Just awaiting new pdf instruction to become available
Then more updates will be posted
Thanks
4 Pages «<234
This page was generated in 0.199 seconds.
